Measuring Lift
Old Sep 22, 2006 | 08:30 AM
how do you measure lift on the head studs? thats been bogglin the mind lately
and before you say id
no arp head studs fo me!!
just stockers
for example hma says do this to the head studs
M10: 30 Nm (300 kg.cm, 22 lb.ft) + (60�-65�) + (60�-65�) M12: 35 Nm (350 kg.cm, 26 lb.ft) + (60�-65�) + (60�-65�)
the 60-65 degree thing someone told me means lift
Old Sep 22, 2006 | 04:36 PM
Isn't that the angle on the threads?
Old Sep 22, 2006 | 04:39 PM
i have no idea what it is lol
someone just said it ment "lift"
Old Sep 22, 2006 | 10:54 PM
tdonnell's Avatar
Dunno about lift. I would only think that means how much the bolt is stretched.
As for the distance between the threads, that is known as the pitch of the threads.
Old Sep 22, 2006 | 11:00 PM
Denisst99's Avatar
it's not lift. it's rotation
for the M10 bolts torque to 22lbs/ft then add 60 to 65° once all done add another 60 to 65° more
for the M12 bolts torque to 26lbs/ft the add 60 to 65° once all done add another 60 to 65° more
basicly you torque all the bolts, then add a bit more then a quarter turn to all of them, then add another "bit more then a quarter turn"
a eight of a turn is 45° quarter turn is 90° so basicly it's about 5/32 of a turn
those are called torque to yield bolts
Old Sep 23, 2006 | 11:35 PM
Ahhhh I see now that makes a lot more sence lol
Thanks
Old Sep 24, 2006 | 12:54 AM
tdonnell's Avatar
So we do have TTY head bolts?
I am doing a P&P head soon, might wanna do the arp studs huh?
Old Sep 24, 2006 | 01:34 AM
Denisst99's Avatar
i knowa few guys who reused old head bolt with turboed cars..
so far. .no problem, so in your case wit ha N/A car i doubt you'l lget a head bolt failure..
if you have extra money. .go for ARP or new OEM ones. .
but if your short on cash.. reuse the old one if they're in good shape
