Vehicle Bogging Under Wot?!
Old Dec 24, 2006 | 10:53 PM
t28turbulence's Avatar
Ok so I just dropped my low mileage motor about to drop the turbo back in in a week or so. The car is driving Perfect aside from my tps Issue .... as a matter of fact. better than perfect, fast as hell (curious)
Out of no where I start it up one day and when i give it 75% throttle it boggs and feels and sounds as if the fuel has been cut off... or flooding the cylinders. I went to my local autozone and they ran an obd2 check . it came up with two codes. One was the tps which i already knew then some code P1606 Aux. out aux. In
When i called the dealership they told me that code had to do with a faulty acceleration sensor. Has ANyONE heard of something like this???! HELP!!
Old Dec 24, 2006 | 11:26 PM
so the turbo is in, yes or no? and what is your setup? it could be something about the way your turbo is setup.. do you KNOW its rich, or could it be lean?
Old Dec 25, 2006 | 09:48 AM
turbo is not even in yet man. motor is stock
Old Dec 25, 2006 | 11:59 AM
hamhead's Avatar
Inspect, and if necessary, Replace the sensor that the code says to?
Old Dec 25, 2006 | 01:47 PM
the acceleration sensor is the sensor that you have to alter when you put on a front strut bar. its on the driver side strut tower.
run a search on here to find out more info on it.
