Car Stalls At Wot
As the title says, as soon as I go WOT in any gear, 90% of the time, the car will stop accelarating. If I let off the gas immediately, the car will idle, but will not respond to the throttle unless I restart the car. If I don't let off the gas immediately, the car will stall as soon as my foot comes off the peddle. The car runs normally after I start it again, until I go WOT again.
I thought that as well, considering I was getting P0123 - TPS voltage input high. I put in a keifco TPS and that stopped that CEL from coming back on. But I'm still having the car stall at WOT. The TPS is tested and working as according Webtech. I also hooked my computer up to the car and it shows the TPS matches the RPM's and MAF readings at each level.
