Car Running Poorly, Is It Fuel Injectors
my car is running poorly. ive had new plugs and wires and all belts and pcv valve.... could it be clogged
injectors that need cleaning?? i can smell a rich fuel mixture
causing me to think its injectors??
should i also change the fuel filter??
and what is the cost of injector cleaning??
my mods are catback exhaust motoria and aem intake.
if u smell gas, then i wouldnt think it would be the injectors. did u do all the stuff above before or after it started happening because maybe u have a spark issue that its not igniting the fuel therefore your gas smell
If yer exhaust system is very new too it could be somthing as simple as that, they might not have put your cat back in and therefore you'd smell more fuel. Need more info on the siteation.
