Doing Some Calculations
Old Sep 15, 2006 | 08:31 AM
JonGTR's Avatar
I need to have the car running over 300hp by the end of the month. 320hp is roughly where the stock TB/manifold combo limits us. However, it is probably only one of those and this can be an easy fix for me to do within the next few days.
Stock TB diameter = 54mm
Area = 3.53 sq. in.
Now, I don't have the exact dimensions on the manifold runners here at work, but I'll get them tonight. So for now, we'll just plug in theoretical numbers:
Stock runners = 1" or 1.25" (x4)
Area = 3.14 sq. in. or 4.9 sq. in.
So you see, depending on the size of the runners, it may just be a TB restriction. In that case, I can easily cut off the stock flange, weld on a bigger one, and bolt on a 65-70mm mustang throttle body. Then I'll be good for quite a bit more power.
Anyone happen to know the measurements of the IM runners?
Old Sep 15, 2006 | 10:13 PM
Viper966's Avatar
the limit isnt the stock TB and manifold... the owner of seoulfulracing is at 400WHP on stock TB and intake manifold
dont forget your Pressurizing the manifold so you have more oxygen per cubic inch of air when u add pressure... so while ull have to raise the boost more to achieve your WHP goal the TB cant ever really LIMIT the HP output just slow it down
Old Sep 15, 2006 | 10:44 PM
JonGTR's Avatar
You said yourself that the TB and IM was limiting you.
QUOTE (Viper966)
Car did 317 WHP and 320 Tq
i kinda ran into a wall @ this level, it seems the stock manifold/tb cant flow enough air right now...
Old Sep 15, 2006 | 11:28 PM
Viper966's Avatar
yea i did, until is saw what seoulfulracing guy did and i installed a bigger TB/airram and all it did was smooth out my powerband... didnt gain much MAYBE 10whp.... but it got easier to make power
what was holding me back before was me not advancing my timing out enough
now with my methanol injection kit and the knocklight i make ALOT more power alot easier and the gt35r doesnt hurt
Old Sep 17, 2006 | 08:44 PM
JonGTR's Avatar
Measured the stock intake manifold.
1.25" x 1.875" oval x4 =
6.88sq. in.
so......
Stock throttle body = 3.53" sq.
Stock intake manifold runners = 6.88" sq.
70mm throttle body = 5.97" sq.
So this concludes that the stock intake manifold runners are good enough to flow more air than even a 70mm throttle body, as long as you cut off the throttle body flange from the plenum.
Old Sep 17, 2006 | 08:51 PM
Alex01tib's Avatar
you mean if you cut off the flange and weld on a bigger flange?
what if you bored the flange?
Old Sep 17, 2006 | 08:55 PM
JonGTR's Avatar
Yes, I'm talking about cutting off the flange. I don't know if there's is enough material to bore out the flange. Although the Rside 70mm bolts on.
But we can't get those anymore. So we're now talking about Mustang throttle bodies. So you'll need to weld on a new flange anyways. They're available pretty cheap.
Old Sep 17, 2006 | 08:57 PM
Alex01tib's Avatar
really, where can you get flanges for a mustang throttle body? (getting really interested lmao.gif)
Old Sep 17, 2006 | 09:00 PM
JonGTR's Avatar
The throttle body that I got was made by Proffesional Products. I believe they also make the flanges.
I'm not 100% sure since its a dumbestic company. My friend still needs to get me the flange. I'll ask.
Old Sep 17, 2006 | 09:07 PM
Viper966's Avatar
flanges are easy to make... anyshop with a flowjet can make u one for less then 10 bux
