- Check out a new turbocharger system I built
- Large intercoolers
- How hot does the cold side of the turbo get?
- What on average will a shop charge to install a kit?
- My car video
- holset turbos
- iat sensor
- problem with pressure
- Oil Pressure required at Idle
- Equal Length vs Log Manifold
- Quick connect couplers
- What size IC piping?
- This is sad. HKS USA is closing
- Finally turbo
- megasquirt
- Surge tank
- Beta I oil pan on Beta II
- bad to spin a new turbo by hand?
- air 2 air or air 2 water
- Video of my car idling
- Is it possible to tune a car without going on a dyno?
- is it worth upgrading oil return to threaded fittings?
- Wideband install help
- radiator size
- Turbo oil drain
- Custom twin charge setup
- Running a turbo without the intake hooked up?
- Finally got my new Turbo
- Knockoff turbo parts versus real ones
- Man i am so close to finishing this
- 50 trim vs 60
- Balance?
- Tib back to life progress thread
- Bta swap Turbo
- Ignition and high horsepower
- I really would like to hear HA's opinion of this turbo technology
- What, exactly, is "trim"?
- Its been a fun 8 years!
- Finaly ordered my last few parts
- In the market for fuel system
- engine stress, psi vs hp
- Boost Creep..?
- lifting the head?
- Forgive my newbiness
- Stock flywheel
- Part throttle boost/ lean condition
- Stock fuel pressure
- Question about blow off valves
- Considering going turbo on 1.6l
- Cheap intercoolers
- Math problem ! boost=compression
- Can I see some of your gauge set ups?
- spool up diffrences in precision .64 from.82
- 11.9@129 on street tires!!!!
- apexi neo tune help
- underdrive pulley
- Those of you who live in a state with smog & emission testing
- Ported intake mani
- injectors
- fpr
- Kfx MAF to MAP ecu?
- Anyone pushing more than 30+ pounds?
- Turbo Rotating Clamp. Turbonetics t3/t04e
- Overheating with Watercooled turbo
- Car overheats since turbo install
- Help! Car wont rev...!
- HKS BOV Fluttering: No Pshhhh
- Suicidal Turbos
- garrett or turbonetics?
- Borg Warner EFR turbos
- fabbing my exhaust
- Low impedence injector help
- Installed on the Genesis: AEM CAI + AEM FMIC
- my new fuel pump
- Break in on freshly boosted engine
- 12.4@126mph/513hp-461tq
- hot side piping pics
- T3 vs T4 housing discussion
- Do people notice your intecooler?
- 3 tuning places in mind
- How many cars have you owned that had FI?
- 255lph fuel pump
- Can you be pulled over for having too loud of a BOV?
- My intercooler piping pics
- Injectors, mega squirt.
- Getting a boost project started
- Never buying an ebay BOV again
- FPR questions
- Time for fueling, need advice!
- open dump waste gate
- Oil Feed
- G4GM Motor
- New turbo
- Post pic of your catch can setup
- FMICs
- Need a dimension for treadstone manifold users
- What oil to use for turbo app?
- Oil Feed lines to turbo
- computer wiring (standalone or piggyback)
- 2001 tibby turbo install help/tips
- Confusion with NGK Spark plug codes
- Adjustable intake cam chain sprocket
- flat faced valves or dished?
- Kspec Motor Mounts
- GT35 or bigger
- Are superchargers a dead technology?
- oil cooler
- Do IC sprayers make a big difference?
- Whos using a stand alone with their turbo set up?
- When to do Tuning
- front exit exhaust?
- Whats the highest hp turbo'd beta thats still on stock internals?
- What makes the ebay turbo systems all junk?
- Revamping the fuel system
- TD05 Big 16G Turbo
- Boost vaccumm
- twin turbo on a 4 cylinder
- pauter rods
- My dilemma
- fmic piping
- Turbo Timer on a 98 Tiburon
- Daily Driven Tiburon 11.44@128
- Whats the purpose of a fuel cooler?
- Going to be doing a few winter mods.
- engine surging
- Garrett T3/TO4E 57 Trim, T3/TO4E 50 Trim or T3/T4 57 Trim
- Turbosocks turbo kit on higher compression
- Which is a better turbo to go with for a V6?
- What PSI are you running on the streets?
- Water and air cooled intercoolers
- Turbo size on the Sonata Turbo and Gen Coupe
- 2.5" exhaust instead of 3" for turbo
- Turbo compressor keep getting lose?
- oil pump ?
- Boost Leak?
- Every got anything weird stuck in your intercooler?
- Has anyone tried the Synapse BOV?
- Stock thermostat with boosted engine?
- Need some info on twin scroll
- Cost to install turbo kit
- Cold Starting - RPMs rev high
- Head Gasket for Turbo RD1
- what makes one FMIC better than the other?
- injector questions
- My car slipped off the dyno
- t3 gasket blowing
- Properly sized turbo
- Blow off valve...when do you need it?
- Colt cams
- Differentials
- An electric supercharger that works?
- AEM FIC MAP pls share
- some advice
- School me on intercooler piping!
- Turbo help
- Dyno questions
- Turbo Spool Guide
- Proper warm up for a turbo engine
- Internal Wastegate Settings
- bad gas?
- Supercharger Rebuild Shop
- leaking turbo
- Anyone ever had engine exploded from bad Tuning?
- AEM Fic Software
- how long did it take for you guys to finish your turbo builds?
- Is this true?
- turbo on 93 sonata???????
- Swap to E85????
- lets talk wastegates. warning: might be a silly question here
- This is interesting. Compound turbo?
- Finally Turbo'd
- plug & play piggy back?
- Making Super charger manifold
- Right size injectors
- Jet Chip ecu upgrade kit
- Turbo exhaust help
- Cheap Billet Catch Cans
- Larger Turbine wheel what affect will it have
- turbo mounting location
- Sparkplugs and turbo
- How bad is crush bent IC piping?
- keep it or turbo it!?!
- opinion of turbosmart products...
- What I Need, What I have for my Turbo Build
- More boost
- SC Belts
- Explain this intercooler setup
- Going Turbo Very Soon, What Stand Alone Do I Choose
- 99 accent turbo
- Car "burping" after shutoff - Any Walbro users getting this too?
- Selling Price: $89.99, You save: $110.00
- n00b question - at what point is it time to upgrade internals?
- Twin Scroll Turbo Systems
- Radiator as an intercooler?
- 3 in 1 Gauges - Boost/EGT/Oil Pressure
- Revotibs Evo 8 Turbo build
- Intercooler Sizing
- vacuum lines
- Trying to prevent water/meth from evaporating
- What causes more wear and tear on an engine, n20 or turbo?
- Hks Ssqv Bov
- Stock FPR with Walbro 255 HP
- Where can I learn about proper turbo sizing?
- is this possible?
- Water to air intercoolers
- Lots of questions, biggest reguarding vacuum?
- Air Conditioning and Boost
- OH YEAH!!!!!!
- What in the world is this???
- Best way to clean a turbo?
- Some old Supercharger pics on a Beta....
- Alky inject and E85 differences?
- 2.0 inch cold pipe 2.5 hot pipe? or all 2.5?
- N00b question about oil return line
- Whats everyones thoughts on a 50/50 BOV?
- Rebuilding a turbo
- Venturing into the unknown boost & N2O
- Whats better - equal length manifold or log style?
- Got myself a new water/meth injection kit
- Q: Why couldn't the NGM supercharger fit RD Tiburons?
- Spark Map
- Turbo drain pump
- Intercooler couplers
- Wish there were more supercharger options available for us beta owners
- At what point do I need sleeves?
- How many people are running e85?
- Turbo timer times?
- New Dyno Numbers are in!!
- Can somebody explain to me what turbo compressor surge is?
- What I Have Been Up To Lately
- Cracked Mani
- Turbo vacuum blocks
- Copper or Platinum plugs with turbo
- Oil change intervals with turbo applications?
- Possible to do a turbo set up for $1500?
- Meth kit maintenance?
- Manifold gasket
- Water/meth consumption on road course
- Dialing In Cams
- Doh! (homer's Voice)
- Massively Gigantic turbo anyone?
- Buying a used turbo
- Whats Next?
- Turbo blankets
- Top mount IC
- Question about boost in EVAP system?
- Tial 44mm wastegate. Is this diaphragm ok to use?
- Intercooler piping size?
- Alternative Injectors Available
- AEM Performance Electronics
