- Beta2 Alpine Supercharger
- High compression pistons
- Spark plugs
- Greddy Emanage VS. SMT-6
- USA RD to KDM RD engine swap
- Beta swap into an accent?
- TE04H Turbo Issues
- 6 speed for the 2.0?
- Ground Wire system?
- Narrowband to wideband?
- KKK turbochargers?
- My Turbo Goals .. Suggestions?
- Question about Wideband O2's?
- lean situaton and boost problem
- What is Karmann Frequency?
- wideband O2?
- Turbo manifold question
- S-AFC vs SMT-6
- Blowing a Boosted engine
- Any interest for Apexi IHI turbocharger only 380hp
- piping problems
- Knock and Detenation
- Turbo And Inspection
- What Engine is better to boost?
- Knock sensor display?
- Turbo manifold advice needed
- What to do (a/f ratio ???)
- Evo engine in a tib
- Help me to build low budget turbo kit
- Double fuel rail
- new exhaust..
- intercooling question.
- Anyone live near or in Minnesota?
- boost problems
- What im up to...
- Boost Calculator !
- Safe psi?
- Technical intercooler question.
- Turbocharger items for a 2000 Tib
- greddy emanage
- Hard to Believe
- Alpine vs. KSPEC
- 1.8 or 2.0
- haltech inspection
- Superchager too much for the engine?
- Vortech FMU vs RRFPR
- ultimate turbo set up
- What are the step to follow after install a turbo kit....??
- Turbo Exhaust Question
- Turbo Question
- Slim/thin fans?
- Stock injectors?
- Dropping the oil pan...
- Raised the Boost (Vid inside)
- Turbo Manifold w/out Turbo
- IAT location
- Turbo Question..
- my motor is on it's last leg... what should i do?
- Internal to external gated?
- couple intercooler questions
- Pre Turbo advice....
- 12psi Run Videos
- GST- Fuel Pump Installed
- Twin Engine Tib
- How do you find an exhaust leak? Best way to mount a turbo
- Need pics.. especially from you Jaws.. FMIC help!
- Questions about a temporary alternative to boost.
- Exhaust Gasket compound
- Intercooler Pipes
- A little birdie just told me....
- strating turbo project help!
- cam question
- turbo timer
- what gauges to get for boost??
- Turbo on 200k?
- when should I put new clutch?
- Turbos
- Sleeper Project
- Pre-turbo
- intenal or external
- Aftermarket Pistons
- Speed-Factor turbo
- trustworthy
- Internal Vs External
- Max Boost
- wondering about 300whp
- Turbo Blowing oil into intake
- where can i find a cheap turbo
- What are the best sparks I could buy?
- Will a turbo's intercooler fit under my vader bumper?
- Need Turbo Advice!!
- Turboed? how much milage?
- Turbo Warrenty
- 04 CVVT Turboed - Speed Factor kit
- Eclipse Manifold..
- WARNING: Electric Superchargers, Spiralmax, Tornado etc..
- electric supercharger?
- Lots of Money and searching for ideas.
- another project
- Boostin a 97 tibbie
- Difference in turbos???
- hp stock rods
- Finally picked a goal....
- 96 talon injectors
- ok.. run this by me one last time
- aftermarket MAF + SAFC
- Perfect Turbo for Tiburons...cooming soon!!
- Been installing the Speed-Factor kit since 10/9, see inside!
- average whp turbo question
- Cheap way around an FMU or RRFPR
- turbo maintenance???
- How much boost on stock head bolts??
- Turbo mods
- I4-V6 engine swap
- spyder eng swap
- Wanting to run 10-12 sec 1/4's what to do ?
- What to do!?!?!?
- pistons and rods
- speed-factor turbo kit
- Turbo plan...more or less.
- faster car
- Light Turbo on stock fuel supply?
- Newb question? SC or TC
- Getting Car turbo ready
- haltech question
- My SS turbo exhaust manifold custom made by AXIS
- Alpine supercharger....anybody have one???
- 01 tiburon beta swaps
- PPSSSTTT Speedfactor
- ~Tasty~ --- The Speed-Factor turbo kit has arrived, pics ins
- Beta I to II conversion
- haltech
- boosting a MAP based car
- air ram intake manifold
- OMG!
- Turbo Question
- Tim please read :) GT28RS
- hp rating of stock internals?
- Engine Swaps
- Standalone
- Turbo questions
- Exhaust question for FI engine
- welding...
- e-manage hookup HELP
- super 60 turbo questions
- kspec manifolds
- Not enough fuel
- white smoke
- Beta 1 2.4L Engine head swap
- still having major problems
- updates...been a while**better quality pics uploaded**
- Error code 1124
- Has anyone done a engine swap to the sonata 2.4L
- Q about fuel
- Posting in this Forum (PLEASE READ)
- 92-95 Elantra 4G63 Swap:90 E-Prom AWD ECU in my Elantra Swap
- alpine turbo problems
- Link Standalone engine management systems (interest)
- 92-95 Elantra 4G63 Swap:Diagnostics mode in the elantra swap
- 92-95 Elantra 4G63 Swap:Went to start the elantra and....
- 92-95 Elantra 4G63 Swap:water line off of oil filter housing
- Oil LIne
- 92-95 Elantra 4G63 Swap:1G DSM PS pump on the Elantra
- 92-95 Elantra 4G63 Swap:Driver side suspension brace
- My project.
- Beta 1 Superchargers?
- Boosted Cars on this site? *ADD PICS!*
- 92-95 Elantra 4G63 Swap:Knock Sensor?
- results?
- hwarang pistons
- 92-95 Elantra 4G63 Swap:Battery relocation
- Anyone wanna help me find parts for my project beta 1?
- AirRam intake is in
- Lean
- what kind of turbo manifold is best?? (reposted)
- 92-95 Elantra 4G63 Swap:Elantra Swap Tranny
- Turbo Timing/Misfiring
- Urgent Help on Turbo!!!!
- The BOV, is have to be between the TB and the Intercooler?!
- Timer Installation
- Best type of turbo manifold??
- turbo fuel PRESSURE *Title edited by Admin for searches.*
- Colder spark plugs for turbo setup
- Turbo Manifold
- turbo installed....yeah!!!!
- How can I Install a Boost gauge?!
- I´m gonna install my turbo system this weekend!
- TURBO TIMING
- adding a Turbo Kit to my 2000 Tibby 1.6 NA?
- Turbocharger options
- Where can I get S-AFC numbers for a turbo Tiburon 4-6 psi?!
- Missfire?
- What is this out thing for? its from a turbo Tiburon....
- FMU - FPR - Fuel Pump
- what I need to run my Tiburon at 4 psi?
- is true that automatic trannis likes to blow up at 5 psi?
- retard timing
- Need an opinion
- how do I run an open BOV
- before you turbo
- RD Tiburon HP gains
- Fuel Injectors Opinions
- Vortech FMU size?
- SAFC II or E-Manage
- Turbo
- has anyone used the MAP-ECU on a tibby
- what size Injectors would be best for 10-12 psi
- Speed-Factor Basic Turbo Kit
- BOV, MAFs and boost?
- Need some advice
- good or bad $349 k-spec turbo pistons
- turbo or sc for 99 i4 auto
- Turbo Build
- Which turbo mainfold do you like?
- Make me fast
- What do i need to do to my engine for turbocharging??
- price on a good turbo kit
- Garrett T1
- 99 tiburon turbo?
- RIPPMODS SuperCharger Help request...
- 2001 Tiburon Turbo ?
- Beta I @ 2.2L and 15psi?
- best exhaust manifold for 1.8L engine
- Stage 1- Getting ready for turbo
- Wiseco pistons?
- TigerLily BBTB for RD
- Turbo question
- Who's broken the 300whp mark?
- Guess what I'm getting this week :)
- ecu piggy-backing
- is it worth getting let me know.
- does any one have pictures
- turbo pistons
- SPEED_FACTOR TURBO KITS
- Well, doing some of my net whoring today, I found this...
- supercharging 101
- k-spec rules
- CNK Turbo Kit
- Choosing a turbo
- Want to see turbo manifolds for the 2.0L tibs from HKS?
- TURBOED(wut u think?)
- alpine turbo kit
- turbo fuel pump
- need help with bottle placement with new trunk set up
- Kspec.com New Product: RSide Turbo Throttle Body
- need help turboin my tibby
- blow off sounds
- Question for the turbo guys!
- turbo vs. supercharger
- cnk and chris are alive!!!
