aftermarket MAF + SAFC
Old Oct 13, 2004 | 12:01 PM
azwildfire's Avatar
Default Re: It's my birthday!
since the stock MAF dies after about 260ish WHP ... can you use an aftermarket MAF with the SAFC to tune above that? much like using a larger injector? or would you have to go stand alone or have Real engineering re program your ECU?
Old Oct 13, 2004 | 12:04 PM
Dweet's Avatar
Default aftermarket MAF + SAFC
reprogramming an ECU is just a temporary work around. everytime you upgrade something on your car you'll have to get it reprogrammed. if you can afford it standalone is the best thing to do. an S-AFC will not make an aftermarket MAF work. you'll need a MAF translator like the ones DSM people use when they put a corvette MAF on their cars.
Old Oct 13, 2004 | 12:07 PM
tibwrcsbj's Avatar
Default Re: 180 Km Top Speed???
and last i heard real was NOT able to reprogram the ECU for MAF, only MAP.
Old Oct 13, 2004 | 01:20 PM
aftermarket MAFs are possible, youll just need to find one that has the same voltage range as ours does. or, if you are real apt with electronics, find any one you want and use some kind of resistor to bring down the voltage, and hope it will still fall in the correct range you need.
dweet, you got a link for a MAF translator? id like to read up on them a bit.
Old Oct 13, 2004 | 03:10 PM
Dweet's Avatar
Default Re: Turbo mods
hrmm let me see
http://www.dsmtuners.com/parts/product_inf...b1a74222436fffb
http://buickgn.com/enginecontrol.htm
i couldn't dig up any schematics or anything...
Old Oct 13, 2004 | 09:25 PM
OdessitPashka's Avatar
Default Re: What happened to KORE???
350z and sentra spec v have 5V mafs. this one guys with his sentra is pushing over 300whp now smile.gif
Old Oct 13, 2004 | 10:40 PM
Default Carbon fiber hood weigh difference?
i really dont know, but are the increments the same though?
just because something has a 5v maf, does it mean that at that specific MAf's 3.3v our hyunda ecu will be reading the same amount of air as the sentra?
im pretty sure it is, but just want to be positive.
good read on MAF sensors for anyone who wants to know how they work...
http://www.kemparts.com/TechTalk/tt06.asp
Old Oct 13, 2004 | 10:48 PM
Default Re: Carbon fiber hood weigh difference?
true, but most likely it will work just fine. If I ever max mine out I will try using something different, it's worth a shot!
Old Oct 14, 2004 | 07:22 AM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
Default Re: 2004 ABQ BBQ - Who's Coming? (ABQ = Albuquerque New Mexi
Hey thanks for that link Tibby01, it's nice to know stuff like that.
So what happens if you exceed the limit (in terms of hp) for the MAF sensor and ECU. Does the car just run crappy, going lean/rich or will it cause mechanical problems like misfiring and detonation? Is the only cure a standalone with an aftermarket ECU??
Old Oct 14, 2004 | 07:53 AM
Dweet's Avatar
Default Re: Type R Wing Group Buy *CLOSED*
i should have put this in my original post. With a GReddy E Manage once the MAF is maxed out you can use a MAP sensor as well with the E Manage. So not only does it take the stock maf's reading in acct before it hacks the signal before it gets to the ECU, it takes a separate reading with a MAP (the MAP is of course extra) and can add additional fuel as needed once the MAF is clamped.
