aftermarket MAF + SAFC
Old Oct 27, 2004 | 12:23 PM
  #71
FordFasteRR's Avatar
Default Re: Turbo Gaskets
QUOTE (OdessitPashka)
DSMs use hertz for their reading for ecu we use volts
well, obviously, the SAFCII will convert the input readint from the eclipse MAF to the output reading specific to our cars... thats the whole point of that manuals instructions right ?
also, I spoke to John from alpine, and he told me that the current beta 2 blower is set to 8 psi stock.. lol smile.gif OHH YEAH !
Old Oct 27, 2004 | 12:32 PM
  #72
OdessitPashka's Avatar
Default Re: FS: Front and rear sports engine mounts
I guess, you just gonna have to do some wiring work. Still not sure how this all will work out.
Ford, arent you suppose to have your kit by now?
Old Oct 27, 2004 | 01:07 PM
  #73
Dweet's Avatar
you think i dont know this already?
apparently the S-AFC II uses some kind of translator in it. However im still wondering the effectiveness of it because the ECU still reads 5v as max and if the hertz gets too high to translate to 5v or less... the computer might freak out and make my car explode.. well not really but whatever it does after freaking out might be scary..
Old Oct 27, 2004 | 01:15 PM
  #74
Default Re: 97 Tiburon vs. 03 Acura RSX type S PART 2 !!!!!!!
did you ever fix your elantra?
Old Oct 27, 2004 | 01:27 PM
  #75
Default Re: Ebay kicks arse
it has a conversion scale that adapts to whatever the input signal range is.
regardless, an input signal must have a minimum and maximum output... that is taken into account during the translation, so it wont to gover 5v to the ecm...
sheesh.
Old Oct 27, 2004 | 01:37 PM
  #76
Default Re: Best bodykit for RD1
so basically if you do the wiring right and hack the SAFC2 you can go over the MAF limit, but then on the other hand you will need to control your fuel and it won't be possible with only 50% cut that SAFC2 provides
  #77
Dweet's Avatar
Default Re: aftermarket MAF + SAFC
depends what you mean by "fix"
yes it runs, but it has a boost leak and gets shitty MPG
