- Ebay Turbo Kit For 01 Tib! But Is It Worth It?
- 01 Tib, Turbo Or Supercharger?
- Bot Gauge Wire Hookup
- I've Come To The End Of My Road.
- Siemens Ecu Remap
- Car Alarm W/ Built-in Turbo Timer
- Ngm's Supercharger Is Done
- Pistons..what Shall I Do?
- E85 Conversion!
- Need Some Help With Msd Coils
- Turbo Kit
- Ericy's Turbo Build Pics
- Aem Fic Wiring
- White Smoke When Shifting
- injectors. beta 2
- My 553hp Elantra
- Interesting Manifold On Ebay.
- Aem F/ic Wiring Diagram
- A Trace Of Oil And Exhaust
- Experts Help Please....
- Bov Does Not Hiss
- Smt Map Sensor Calibration.
- Anyone Want Custom Parts Made?
- External Wastegate With Mbc
- Smt-7
- Help! Car Wont Start Up!
- I Really Need Some Help Here
- Coming Over
- Msd 62112 Help
- How To Datastream Obd1 Ecu?
- J & S Safeguard
- Airram And System Upgrade Bbtb
- Maximum Intercooler Size For Rd2 ?
- Greddy Emanage Vs. Smt-6
- Turbo Setup Help
- Twin Engine Tiburon
- Compression Question
- Re/build Pics.. Track Day ,dyno ,vids
- Tuning At Partial Throttle?
- Going Turbo, Question About Intake
- Can Some One Send Me Thier Smt-6 Map?
- People With Mustang Tb?
- Hesitation During Boost
- Bolt-on turbo for tiburons (wondering if it would be any good?)
- Smt-6 Software
- Newbie looking for a turbo kit for tiburon 2.0l
- Secondary Fuel Rail Issues.
- Turbo Setup Questions
- Need help finding updates for E-manage Blue..
- Coolant Feed/drain Line Location
- Pauter Rods Help!
- Engine Temperatures?
- Water Methanol
- Eturbo
- Ebay Alert! Turbo Manifolds
- Log Manifold Question
- Compressor Side Oil Leak
- Fabricating My Own Manifold
- Turbo Kits
- Having Trouble In My Secondary Injectors
- Oil Leak On Top Of The Engine?
- Finishing Up The Turbo Kit .... Got Some Questions
- What Is Needed To Run Low Impedance Injectors
- Alpine Turbo Kits
- Need A Base Map For Smt-6
- Adding a FRL to install FPR...
- Rebuilding A Beta Engine
- 350 Whp In Need Of A Clutch
- Advice On Which Turbo.
- Diy: Large Bore Direct Fit Maf Sensor Housing, Courtesy Of Saab
- New Intake Manifold Progress Thread
- Sr20 Tib ?
- Installed Smaller Supercharger Pulley
- How Hot Does The Air Get Coming From The Turbo?
- Transmission Weakest Link?
- Where Can I Place Extra Injectors
- Found A Neat Nitrous Diy
- Crazy Turbo Hesitation
- Just Have To Ask...
- Where It Place Extra Injectors?
- Kspec Manifolds
- Turbo Input
- Supercharger For '00/'01?
- Ericy's Turbo Questions
- Vacuum Lines Confusion
- Perfect Power Smt-6 Questions
- (vids) My turbo Elantra
- NGM Enforcer now out
- What You Tuning With?
- Trying To Intercool My Supercharger?
- Wideband Kit?
- Turbo Oil Feed Question
- Haltech Interceptor
- Thinking About Getting Cams.
- I Need A Complete Turbo Kit
- My Beast Runs!
- Turbo Install Day 2
- Colder Spark Plugs
- Rd1 Ic Piping As Well As Other Questions
- Bumped Boost To 25psi And Dynoed
- Engine Tuning
- What Turbo
- Megasquirt Stand Alone Disaster
- Turbo Questions
- What To Do Next
- Rd1 Fmic Mounting
- Oil Return Line
- Fuel Rail
- Diy Head Port & Polish
- 2003 Tiburon Intake Cam Specs
- New Head Gasket - To Decompress Or Not
- Billet Aluminum Rods
- Turbo Questions
- Sr Special Stage Turbo Kit Thoughts
- Boost Without Tuning?
- Cam Timing
- New To Boost
- Cop Setup
- Tuning Problems
- Haltech
- Turbo Ecu - Smt6
- Turbo No.
- Alpine Developments: Update
- Turbo Oil Lines
- Ecu
- Low Boost On Stock Compression
- Oil From The Dipstick... Continues To Make A Mess
- My Turbo
- Want A New Turbo!
- Does The Teo4h Just Totally Suck?
- Mitsu 420a Or 4g63 Intake Manifold.
- Kustomized's First Turbo Drive... Help!
- 4g63 Exhaust Manifold Similarities
- Ever Heard Of This Piggyback, TurboXS DTECFC?
- Fan Removal For Turbo Setup
- Tiburon Dyno Clip
- Ebay Air Filter Supercharger?
- Inlet Manifold
- Mbc On Internally Gated Turbo?
- Help Me Experts!
- Emanage (blue) Question
- Custom Tib Header
- Camshafts For Turbo Application
- Need Some Help With Alpine
- Haltech Plug And Play Harness - Tests Complete!
- Turbo Help
- Finally Pics Of My 3 Inch Mandrel Bend Exhaust
- Smt-6 Controling Primarys Through Extra Injector Outputs
- Smt-6 As A Semi Standalone
- 12:1 Compresion With Supercharger?
- Cams
- Initial Startup
- 4g63 Rod Modified To Fit Beta
- Aem Ems
- Rrfpr's, Fprs, Fmus Pics
- People Running Low Boost
- Just A Dynosheet For 18psi.
- Haltech Tuning Questions
- Ecu Wiring For A Maf To Map
- Cylinder Head Build
- KSPEC piston/rods
- Turbo Oil Source
- Eaton Supercharger M45 Vs M62
- Need Help With This Turbo?
- Greddy Bov's
- Crazy Idea
- Air Ram Throttle Body
- Spare Turbocharger
- Hyundai 2.0 Beta1 (y.97-01) Spark Map Needed!
- If You Have Pauter Rods........!
- I Need Help Asap
- How To Tell How Much Boost Im Running
- Turbo Prep
- External Waste Gate
- Mituibishi Td04 Turbo
- Megasquirt Tuning Maps Needed?
- Interest In New Intake Manifold?
- Getting White-blueish Smoke
- Car Heating Up Causing Misfires?
- Cams With Turbo?
- Removing Internal Wastegate On 14b
- Going Turbo, What Do U Guys Launch At?
- Turbo Gasket Leaking Again, Help!
- Cutting Stock Exhaust Manifold And Welding Turbo Flange?
- Injectors For Turbo Setup
- Shark Racking Cam Specs?
- Ny's Turbo Project
- Bought A Turbo.
- Turbo Diffusor
- Smt 6 Supercharger/high Lift Cams Map Anyone?
- Custom Made Exhaust Cutout
- Black Smoke
- Supercharger Theory
- Tanc's Turbo Build Thread
- Still No Fuel
- My Turbo Project!
- 6psi Then Wall
- Help With Boost Contol
- Turbo Problem
- My N/a Beta Project
- Radiator Slim Fan
- Trade Safc For Emanage
- Koyo Radiator
- Not Starting.. Grrrr.
- Bov Help
- Check Valve
- Maximum Boost By Corkey Bell
- Custom M62 Supercharger Setup
- Haltech Questions
- Need Fuel Setup Advice
- Dual Rail Install Question
- My Turbo (alex is a genius)
- car sputters, runs lean, check injector clip
- Battery Relocation, Starter Wire Question
- Need Smt6 Maps
- Decompression Plate Or No
- Wiring E-manage Ultimate To Ecu
- Strange Issues With The Car.
- Smt6-having problems
- Apexi Turbo Timer
- Little White Smoke
- Intake Temp Sensor
- Wideband Readings
- Return Line
- Cam for turbo application 1.8 or 2.0?
- Driving On Like 7psi Boost
- Removing 02 Sensors To Stop Ecu Vs. Piggyback Fights
- Soon To Be Boosted!
- Wiseco Pistons
- Powerloss From Cams
- Egt Question
- Twin Engine Tib... Another One?!
- Haltech E8 Base Map
- 500+ Hp Block Build
- E Clip?
- 1.6l Tiburon?
- Help!: Blown Head Gasket
- Taxtrix Cable To Reprogram Stock Ecu
- Turbo And Supercharge?
- Turbo Seals?
- Pvc Setup Causing My Problems?
- Oil Feed Restrictor
- Time For A New Turbo.
- Injector Help
- Racing Spark Plugs!
- Turbos
- Fuel Managment
- How Much For A Turbo?
- Help Id My Turbo
