How To Datastream Obd1 Ecu?
Older tiburon haven't OBDII port,so it is impossible to datastream ECU.
I have seen that Hong Kong ebayers sell an adapter from OBD1 HYUNDAI to OBDII.
Have anyone tried it?
Ehh, was your car made after 1 January 96?
If so, it's OBD2.
http://www.obdii.com/background.html
I've never heard of a OBDI RD.
If so, it's OBD2.
There was no 95 Tib ever if Im thinking right. There were 96's overseas but I dont think earlier. And even some 95s are OBD2. Dont think Hyundai would have had an OBD1 for a year of a model then switched. 95 Eclipses were even OBD2 because Mitsubishi was smart enough to not have to swap everything the second model year.
He may not even have a Tib though also...
All your tiburons use OBDII protocol?????You are lucky guys
In europe OBDII standard became mandatory in 2001,so cars from 1996 to 2001 sometimes use OBDII protocol,sometimes not...
QUOTE (Denisst99 @ Aug 5 2008, 06:24 AM)
euro spec car are WAYYY different then what we have here...
that´s right! i live in germany and my tiburon 2000 has an obd connector, but doesn´t support any obd protocol (neither obd1 nor obd2 !!!). only tiburons from the year 2001 and above support the obd prorocol here!
but because i work in a hyundai garage, i´m able to use the hiscan pro as often as i want cool.gif !
what does the obd port look like on your cars over there? is it the standard obd2 port we have here?
Yeah JBS is right , the german Tiburons before 2001 doesnt support OBD 2 .
I tried it on my 97 and on two other Tiburons build before 2001 none of them gets a connection to a OBD 2 or OBD 1 device.
