Mbc On Internally Gated Turbo?
Can I add a manual boost controller on my internally gated turbo? I believe the turbo is set at ~7 pounds, I'd like to go to 4-5. I was thinking you could add the controller in the vacuum line thats on internally gated turbo's, but I have no clue.
yup, just T it on the line going to the wastegate just like on a external. no difference. and works the same.
but its not gonna go lower then the wastegate is set at. it can just bleed off to gain additional boost.
Vehicle: tiburon SE 2000
i don't know all your mod but i'm running my gt28R at 10-11psi with out a probleme
even pascoile with is t3 is running the same boost
