- Q. Problems installing Haltech
- Maximum Boost
- JAWS 021
- Turbo setup + NOS
- How to read and use compressor flow maps
- Oil Return Idea
- Turbo pistons, rods and cams
- quick question about "DSM" turbo setup
- Returnless Fuel System conversion
- Fuel Pump
- turbo oil lines
- A'pex Turbo kit?
- junkyard turbos
- Twin Turbo Delta 6????
- stand alone dfi system
- Exhaust dilemma
- Looking for Turbo Tiburon Videos.
- Max Boost on Beta II with stock Head Gasket?
- Turbo Delta pics
- Turbo Project. $1500 budget. Lord help me...
- Wideband o2 Sensor
- Cylinder Head Studs
- log style ex. manifolds
- equal length turbo manifold
- turbo is done
- lowering compression with a thick head gasket?
- oil pressure and turbo oil feed line
- what bov and wastegate??
- Fuel mgmt?
- Intercooler size
- Problems after Turbocharger installation
- Help for a turbo project
- Best brand for everything electrical?
- Using 87 octane under FI
- Scoupe Turbo Intercooler Fitted
- Injector / Fuel pressure reg. Question
- What Headers would complement S/C
- Did someone say ebay?
- Are air to water intercoolers more efficient???
- What is Smarter for auto?????
- 250 horsepower ? for v6 tib.
- Fuel Pump Location
- Heres a ? for the experts.
- Having some problems with my car.
- Exhaust systems
- Future turbo vs. SC for 2003 tib.
- My new FMIC arrived
- apexi turbo kit
- Borg-Warner / Airwerks Turbo for V-6?
- Got myself another 30hp from the supercharger!
- Turbo Petition to Hyundai!
- Difference between CNK turbo kit and Real CO. turbo kit???
- new turbo for tiburon?
- RCENG injectors NEED HELP ASAP
- Idea for additional fuel problems
- Engine Management
- auto turbo?
- External wastegate location!
- What do you suggest! EXPERTS!
- Prediction!
- Fuel Atomization idea
- Redoing Turbo set up
- Injector group buy?
- psi vs. cfm
- accent turbo ! (56k warning!)
- My supercharger Dyno Results
- exhausts for turbo setups
- No Turbo for 2003 V6 Tibby EVER!
- stock internals and boost
- MAP conversion
- High Fuel Pressure.
- Ignition control question?
- Who is tigerlily?
- Other mods that work with a Supercharger
- would it make sense to have a bigger throttle body?
- Substitutions for Unichip w/ Alpine Turbo
- Best Place for Turbo Intake?
- Haltech USA closed-prices drop!
- Fifth injector goods and bads?
- td04 turbo quick question
- oil gallery lug wanted
- 1.5 accent s/c...ebay
- Rc 550cc injectors
- Injectors
- need picture!
- pics of engine bay
- Map Sensor
- turbo exhaust manifolds
- More thoughts on engine management....
- What exhausts are you guys using for you turbo setups?
- IHI Turbine
- 550 injectors
- need fuel injectors
- boost creep
- engine menagement
- Turbo Install woes....(HELP)
- '03 I4 Tibruon Turbo Question
- Possible turbo setup for me?
- differences between beta 1 and 2 for turbo
- Cuda kit w/ Turbo
- are t3/t4 turbos the same as t3/t04...
- Ever Heard or discussed about Silverwater Auto?
- APEX'I Turbo Kit for Tiburon???
- MAF w/ BOV question (Yuri)
- Spinwheel Turbo kit $4k BetaII
- Cams
- Buying Spree (turbo)
- Cheaper Alternative to Haltech?
- 03 Tib Supercharger kit
- E Manage with Beta 1 turbo
- adding a turbo to a hyundai tiburon
- stock exhaust manifold for turbo?
- Who's got what I want?
- Twin Turbo Tibby... 7.39 @ 187.5 *Jesus!*
- TiburonTurbo.com
- How's Red's project coming?
- Turbo question
- FORUM ANNOUNCEMENT
- Where to find Fuel Rail
- Fuel line size?
- how hard would it be to make the td05 turbo compatible with the kore manifold?
- Ok..need a low-psi parts list!!!
- Unichip Schematic
- turbo specs???
- Big HP 2.0 Build - My mistake 1.8
- Design specs for Piston manufacture(Red,Random please read)
- Turbo Q: intake manifold and the vacuum lines
- 440cc injectors the facts
- Question CNK /Alpine ?
- anyone know where i can get injectors and pistons other than kspec?
- NEW DYNO RESULTS - UPDATE as of today 01/23/03
- will the kORE manifold fit a td05 turbo?
- wastegate dump pipe question
- Check valves
- A/C FAN Alpine Turbo USERS!
- Zoom article on Supercharger for accent(excel)
- turbo/injector/clutch question...
- Alpine Turbo Question
- almost there...
- air/air or water/air
- where can i find 440cc injectors for a 2000 tiburon?
- Injector Sizing.
- can anyone give me any info or comments on tigerlily?
- IHI RHB 52 turbo spec...
- psi and hp question
- Reproggrammed Stock ECU or Haltech?
- NUTTANICK's engine pics
- haltech
- Accent turbo? Anyone know this guy? Or heard of him?
- Any suggestion for beta turbo?
- exhaust ? for the turbo guys
- Best piston type for turbo?
- i need some support for cnk...
- Ebay... "SPINWHEEL TURBO KIT FOR HYUNDAI TIBURON KDM"
- tib/eclipse
- turbo project questions
- Xmas pressie for all you Forced Induction guys out there.
- Factory intercooler compairson
- Engine Managment.
- downpipe
- Import Racer Project Tiburon.
- Blower on Ebay
- Rod Pistions and Quaife LSD group buy Survey
- IHI vs Garret
- Different Turbo Set UP - Advantages or Disadvantages?
- Turbo Oil-Line Send
- Two puertorican turbo tibs !!!!!!
- Random, Any info on Group Buy..
- S-AFC Turbo setup
- Alpine turbo kit
- Wastegate Question for Cheuk
- I FOUND MY NEW TOY :)
- SR's 2003 Supercharger??? PICS!
- things to look out for?
- Fuel Injector Question
- Best turbo kit? Update?
- those interested in a custom turbo setup
- nitrous as a turbo pre-spooler
- compressed compressed o2
- Question about BOV and Wastegate.
- Turbo Oil cooler/ pump idea
- spiral max
- turbo help
- SAS Kit
- Timing setup
- Custom Turbo..Good Idea??
- Tech Question: P&H injectors vs. Saturated
- stock injectors and fuel pump
- Greddy E-manage?
- ignition timing
- Injectors?
- REAL CO. turbo for 1st gen betas?
- real supercharger on ebay
- Maintainance Interval for Turbo
- Turbo ? for the Turbo Masters of the Universe
- cast pistons
- Super or turbo for Tiburons??
- MSD Ignition
- Pistons
- Crank Position Sensor
- Crower vs Pauter Rods
- Most Basic Setup
- Part number for Turbo application Fuel pump.
- Fuel pump
- Haltech setup? Red?
- Quick Question
- Question on Turbo Tuning?
- is a MAF to Map conversion really necessary?
- T25/T3 hybrid?
- Supercharger drive requirements
- What parts are needed for 300+ HP turbo setup?
- this is a new one I think...
- alpine turbo done
- turbo manifold
- turbo
- turbo automatic
- My Turbo project *UPDATE*
- Electric Turbo???????
- Superchargers
- Quick question on Turbo Car break-in
- Alpine SuperCharger EJ Dyno
- turbo vs supercharger
- Help me find a 3inch Exhaust!
- Turbo ?
- Cheuk, need some input from you about my turbo?
- turbo with stock manifold?
- Turbocharger
- Blow off valves
- Turbos make your car slower
- Working on my Turbo
- Before the Standalone ECU -Turbo question-
- Which Standalone ECU is the best?
- Turbo spool
- Internals to run 15-20lbs boost?
- Turbo Accent in Dallas area
- What the hell kinda supercharger is this???
- Alpine SuperCharger Ion Performance (update)
- turbocharger
- Stock Head for turbo
- turbo or n/a??????????
- My turbo Setup
- supercharger for 03' tibby
- stock turbo on Tiburon to slow... NOS button problem
- Has Hyundai ever produced a turbo?
- I know who is going to Turbo an Accent
- Performance clutch and Alpine SuperCharger
- actual use for a electric supercharger!
- The amazing $39.99 turbo!!!!!
- Turbo Tubing - New Update inside
- Turbo Price Question
