Oil Return Idea
Old May 8, 2003 | 11:59 AM
mcmmotorsports's Avatar
Default Oil Return Idea
Could you tap the oil cap, put a fitting in it and run the return line to the cap instead of the pan?
Old May 8, 2003 | 12:39 PM
Ace_Cobra's Avatar
i dont think...
the oil exit the turbo by gravity...
[ May 08, 2003, 07:40 PM: Message edited by: Ace_Cobra ]
Old May 8, 2003 | 08:03 PM
No, as stated, the oil exits the turbo mainly by gravity. It should be fairly simple for any shop with welding equipment to tap your stock oil pan for a turbo return line. Just make sure they tap it high up on the pan. You don't want the turbo oil drain below the level of oil in the pan.
Old May 8, 2003 | 08:17 PM
Ace_Cobra's Avatar
can it cause problem it the plug is in the middle of the oil pan?
