anyone know where i can get injectors and pistons other than kspec?
i was going to buy the turbo pistons last night, but they emailed me and said i cant get them til late february. anywhere else i can get them? how bout 440cc injectors?
justin:
ive heard that 550s are too big and that they cause problems...
Even installing 550cc injectors with your stock ECU will give you a CRAPPY idle and run into Fuel problems AT IDLE!ive heard that 550s are too big and that they cause problems...
Even if you get a S-AFC and set your low MAPS to -50% all across the RPM range you might still have PROBLEMS where you WLL BE RUNNING RICH AT IDLE!
I would just install 440cc injectors with the S-AFC and you should be fine!
