Stock Head for turbo
Old Aug 23, 2002 | 07:31 AM
xxTIBxx's Avatar
Default Stock Head for turbo
Anyone know if the head will be fine with high psi turbo..
Or if i should get some head work done since the pistons and rods will be getting replaced?
-jordan
Old Aug 23, 2002 | 11:50 AM
Koreandude's Avatar
Well, whats your definition of "high boost"? From what i've learned here...
the head/block/crank should be good for about 600 whp.
drive shafts fail around 225 whp.
differential fails somewhere around 230-300 whp.(i think but i know i'm close)
you're replacing the con rods & pistons so i'm not going there... but when you say head WORK do you mean REINFORCEMENT? I'm sure some head porting and a valve angle job will help for better flow but i believe from all the engine guru's here the stock head is good for the ave. booster. tongue.gif
Old Aug 24, 2002 | 02:17 AM
xxTIBxx's Avatar
Cool.. I didnt know that the stock head can hold up until around 600WHP..
I plan on running up to 400-450 WHP..
-Jordan
Old Aug 25, 2002 | 07:47 AM
Koreandude's Avatar
Good luck man. We're here if you need help!
