Pistons
Vehicle: 1997 Hyundai Tiburon
Pistons
Need to know the tib specs on the pistons. Going with forged wiesco or ross pistons(8:5:1) for my turbo project. Don't want to overbore.
Thanks
Thanks
When you use forged pistons, you go overbore, there isn't an option. Forged pistons require much larger piston-to-wall clearances than a hyper-eutectic or stock piston, and as such the block must be prepped for the larger bore requirement.
Ross is essentially your only option for one-offs. Call Darius (pronounced Der-I-us) and ask him for a set of Tiburon pistons in whatever compression you want. He will take care of everything else.
Also remember that the forged pistons will require either a rework of your stock rods or else new rods. The piston pin on the forged pistons is a full-floating design and the stock rods do not have the appropriate bushing from the factory.
Vehicle: Ex Hyundai Owner
The problem is that anyone has yet to challenge the CNK pistons that far, so there is no way to tell... I would hopefully be taking mine to about 210+ and I'll let you know... from what I'm told yes they are up to 300whp... I trust and believe Chris at CNK problem is that many factors could change that # down or up...
Also before Tony tells you, please learn to use the EDIT BUTTON, and don't double post... thanks
[ October 30, 2002, 11:26 AM: Message edited by: Bat Lord ]
