PDA
View Full Version : Turbo & Supercharge (Forced Induction)
Pages : 1 2 3 [4] 5 6 7 8 9 10 11
  1. Oil pan tapping?
  2. Ceramic Coating
  3. Time for new fans
  4. aem fic
  5. Boosting an auto??
  6. How is an Eaton supercharger's bypass valve controlled?
  7. Check out this turbo setup
  8. Am I missing anything?
  9. t3/t4 manifold for an accent
  10. Alloy radiator choice
  11. Question about twin turbos
  12. Supercharge or Turbo?
  13. Cutting crashbar for FMIC
  14. Turbo cams
  15. People that have spun a bearing while boosted
  16. To paint or not to paint my front mount intercooler?
  17. Blow off valve question
  18. A Little Update On My Turbo Or 1.8 Piston Setup
  19. in need of some turbo advice
  20. Can somebody explain to me in n00b talk how the 5th injector setup works?
  21. Stock headgasket
  22. Help With Aem Fic Fuel Management
  23. Velocity stack or filter?
  24. Rich After Throttle
  25. Pauter Rod Torque Spec?
  26. Aem Fic Wideband
  27. Boost gauge showoff
  28. What kind of manifold is everyone using?
  29. Cant believe people still buy this crap
  30. Smt-6
  31. Boosted Cooling
  32. Twin Turbo question
  33. My Turbo Project Runs
  34. AEM Tru-Boost
  35. turbo shaft play
  36. Blow through and draw through?
  37. Tial bov question
  38. Turbo Similarities Question
  39. injector resistor box wiring
  40. Total cost for your turbo build
  41. People with 350+ hp daily drivers
  42. for those of you with FMIC....
  43. Smt6 Help
  44. How Important Is A Flex Pipe In The Exhaust System?
  45. What blow off valve are you all using?
  46. Which boost controller?
  47. What injectors
  48. Stupid Clutch
  49. Where do you set (display) your Turbo Timer??
  50. Anyone tried this water/meth set up yet?
  51. Thicker weight oil with boosted cars
  52. Turbo Build Help
  53. Are "Screamer pipes" lame?
  54. BOV's on supercharged engines
  55. New Pistons - Query
  56. Where Can I Get Quality T-clamps And Hose Couplers?
  57. Call me nutty, but Octane Booster Home brew?,
  58. Need A Smt6 Map
  59. How much gas mileage do you lose by turboing your car?
  60. Vaccum line
  61. priming fresh turbo installs
  62. Driving With Unconnected
  63. Turbo insulation kits
  64. My setup, well some of it!
  65. Another Boost Project
  66. A few turbo plumbing questions
  67. Funny Problem When Shifting.
  68. My Manual Swap
  69. Short dumptube cause tunning problems?
  70. Boost Of Stock Tune?
  71. Piston question
  72. High psi pump vs Low psi pump
  73. Arp Head Studs Torque Specs
  74. Quaife Lsd
  75. Recirculating or Vented BOV
  76. 10 second street legal accent?
  77. Maximum Boost
  78. The day coming?
  79. probably a really really stupid question
  80. building a 300hp G4ED 1.6L LC2 accent...
  81. What kind of motor oil to use?
  82. Anyone seen this about garrett turbos?
  83. parallel vs piggy back
  84. Turbo quality
  85. Kaboom
  86. Recommend boost gauge, Peak and hold
  87. Need Opinions On A Fuel Pressure Regulator
  88. what plugs to run for water methanol?
  89. Really Going To Turbo The Beast.
  90. Good E85 Information!
  91. wastegate questions
  92. Gm 3 Bar Map Voltages
  93. pros and cons of water/methanol injection
  94. AHHHHHHH my turbo won't fit
  95. supercharging an accent
  96. Test Vehicle Needed!
  97. Overboost Button
  98. Turbo timer parking brake
  99. My Build Thread v4.0
  100. Looking to turbo what opinions
  101. my build
  102. Turbo Tiburon
  103. What non-engine work do you need after turbo?
  104. heres what im doing today. fun!
  105. Follow My Build
  106. Spacer Plate
  107. Compression Ratio And Boost Question
  108. turbo on an automatic
  109. Megasquirt Package
  110. alpine turbos
  111. Matching Manifold
  112. Rear mount turbo systems
  113. Pistons
  114. Megasquirt Diy Pnp
  115. Aem Fic
  116. 1.8 Pistons And Rods.
  117. I'm In The Newspaper!
  118. Oil Pressure Gauge install?
  119. Help Finding Someone In Az To Boost My 01 Tibby
  120. A Picture Book-my Tib Work-turbo-build
  121. Afr Cycling
  122. Turbo Help:Hesitation under load
  123. Narrowband gauge, wideband sensor
  124. Bluerd2's Build Thread- The Turbo-ron
  125. New Project, 2001 Tiburon All Motor
  126. Evo 8 Turbo
  127. boosting the IAC
  128. T15 advice
  129. Smt6 Software
  130. Ignition options advice
  131. Resistor box
  132. Inline Bov
  133. New Top Mount Turbo Manifold, What Do You Think?
  134. Accent went to the track :)
  135. where to tap oil pan
  136. Driving A Turbocharged Car Without Boost
  137. How big can I go
  138. Air-ram Like Manifolds?
  139. Hyundai Excel Supercharger Kits
  140. Smt-6 Help
  141. Jattus Turbo Kit For Sale...
  142. Scoupe T25/t28 upgrade help
  143. Long Time No See
  144. T25 advice
  145. Manifold Question
  146. Tial Wastegate + Treadstone Manifold? Help
  147. Oem Oil Pumps Are Weak!?
  148. Fmic On A Supercharger Kit?
  149. computer help
  150. Electronic/pneumatic Wastegate Controller
  151. turbo grocery list
  152. been out of the "game" for a while need info
  153. Smoking a bit
  154. Is it possible?
  155. Future Engine Swap Possibilities.
  156. Ngm Enforcer Kit Info?
  157. Elantra Supercharger?
  158. Turbo 98 Accent 1.5L
  159. Stand Alone/pistons
  160. Turbo Advice
  161. External Wastegate
  162. Point Me To A 1.8<2.0 Swap Please
  163. Obx Adjustable Cam Gear Issues
  164. Boost On Stock Fuel System?
  165. Stock injector size and questions!
  166. What I've Been Up To...
  167. Matching Injectors and MAF (tibby or sonata)
  168. 1.5L Turbo accent...Idle help
  169. A Dyno Story
  170. New Perfect Power Tf-10 Fuel And Timing Controller!
  171. I Need Advice... Haha Turbo Options For My Car
  172. Plate-fin Heat Exchanger (2 In 1 Out Intercooler)
  173. Turbo Kit From Ebay ?
  174. Jsharptooth91 turbo beta2
  175. Gauging Interest: Bolt-on Evo 8 Manifold
  176. Ebay Performance Chips
  177. Smt-6 Wiring
  178. Let's Play Guess Guess The Smoke.
  179. Electricity Problems
  180. Hooked Up Aem Fic Today
  181. turbo questions
  182. Tibchic's Turbo Project! *work In Progress*
  183. AEM FIC data
  184. need help with turbo decisions
  185. Turbo Setup / Wideband Results
  186. ECM RPM Cut-Off
  187. Turbo drain
  188. How Can Larger Compressor = More Power At Same Psi?
  189. Turbo Cold Side Piping Sizes ---
  190. What To Look For When Getting 99 Tiburon Turbochardged
  191. Engine management & other Turbo Questions
  192. Leaning Out At Low Rpm Problem ...and Some Other Stuff
  193. Aem F/ic Issues
  194. Radu's Turbo Downpipe
  195. Couple Of Noob Questions
  196. Auto-manual-turbo-awwwwyeah
  197. Another Turbo Build Thread...
  198. Compression/idle/timign Problem
  199. Evo 8 Manifold And Turbo On Beta Engine * Pics Inside
  200. Aem Fic-..and Converting To Map?turbo App.
  201. Turbo Manifold
  202. For Those Of You With Turbos And Wheelspin Problems
  203. SAFC II help
  204. Help Me Find A 3 Bar Map
  205. Anyone Ever Seen This Turbo Manifold?
  206. Look At This Manifold
  207. Wot Box. Did You Hear About It?
  208. Frozen's Build Thread
  209. My Turbo Thread *pics"
  210. Wideband
  211. Parts help please.
  212. My Latest E85 Dyno
  213. More Boost=more Power!
  214. Fueling
  215. How To Save Fuel Map In Fic
  216. Sam2000 (ECU Reprogram/Reflasher)
  217. Turbo Maf
  218. Turbo Basics for Noobs
  219. Ic Piping
  220. Beta I and II
  221. Boost/vacuum Lines
  222. Installation Of Racing Piston Rings
  223. Oil Lines
  224. Dual Blow Off Valves
  225. Twin-scroll, Dual Wastegates
  226. Auto Xd Mp45
  227. Aem Fic Tuned And Dynoed
  228. Cant Figure Out What Flange This Is!
  229. Turbo question
  230. Fpr Help
  231. What Do You All Think? Turbo Kit
  232. Yamaha's Other, Other, Other Project. Dragon Fab Twin Engine Tiburon.
  233. PWXL FLASH PROGRAMMER WITH ALIPINE SUPERCHARGER
  234. Pistons
  235. What cars come with T3/T4 turbos???
  236. What Do You Get When You Mix 18psi And A Bad Batch Of Fuel..
  237. Anyone Running A Haltech Boost Solenod?
  238. Apexi Power Fc - Any One Know Which One Can Be Used On Rd1
  239. Starting Research For My Boost Project.
  240. Xclusive's Turbo Build
  241. Internal Wastegate Manifold Fitment
  242. Fuel Management Options On A Low Boost Set Up
  243. Help Finding Turbo For Best Price
  244. Beta 2 turbo.
  245. Beta turbo manifold
  246. Innovative Lc-1 Issues
  247. help!! hyundai getz 1.6 M
  248. E85 Dyno
  249. 1.8 Ecu Vs 2.0
  250. Treadstone Turbo Manifolds
