Megasquirt Diy Pnp
Old Dec 2, 2009 | 08:23 AM
Lazyshot's Avatar
I don't if anyone has seen, but Megasquirt released a DIY PnP kit. So you build it yourself and it is plug and play.
Which is exactly what I'm looking for, but they don't offer it for the Tib. They do offer it for the Scoupe, though.
I don't know if the connections are close to the same, but here's a link. If someone can tell if it would fit
that would be great.
http://www.diyautotune.com/catalog/diypnp-...-kit-p-385.html
http://diyautotune.com/diypnp/models.html
Old Dec 2, 2009 | 08:53 AM
Megasquirt didn't release it, DIYAutotune did. Those sites have been posted and talked about many a time here.
The connectors look similar, as do many BMW connectors, but without better pics or a connector...
Even beyond that, pinouts may be vastly different between these and ours.
Either way it goes, you still have to assemble that kit...
The kit includes everything you need to build an ECU like this - including the case and decals.
and at $430, you better have some good soldering skills. KFX Performance already sells a PnP unit, assembled, tested, and guaranteed to work, starting at $599.
Old Dec 2, 2009 | 10:21 AM
warp21's Avatar
Vehicle: 2000 Hyundai Accent
That will not fit the Tiburons. 92-95 Scoupes and 95 Accents use that ecu plug.
Old Dec 5, 2009 | 12:01 PM
Juanra's Avatar
Vehicle: 1997 Beta Swapped Accent
Some Kia like the 95 Sportage also use that plug.
Old Dec 19, 2009 | 10:34 PM
frozen's Avatar
Vehicle: 2001 Tiburon
I emailed Matt from DIYautotune a couple months ago when I first saw these... Here's what he had to say.
You're right that they are not out just yet, but the first batch will be out very soon. However, we don't have that connector in the first release batch. It's one we have identified as it's used on a lot of cars that use Bosch or Siemens engine management - not just Hyundais. I've got an application list for that very connector that covers everything from the Accents you mentioned to BMW M3s. So it's on the list of connectors being considered for future DIYPNP releases. The connector is a bit of a challenge to fit on the current DIYPNP case design, so it may end up with a different or more expensive case, but we are considering it anyway.
Old Dec 25, 2009 | 07:04 PM
Lazyshot's Avatar
good to know. i'll definitely keep that one bookmarked then.
