Tial bov question
Vehicle: 2003 Turbo Tib
Tial bov question
Gonna be adding more power this year to the car. I have a 38mm bov with what I believe comes with the 11lb spring. Do I need to upgrade the spring to a higher resistant one when I upgrade the turbo and power in general? If not what will happen if I do not upgrade the spring? Any Help would be appreciated.
depends on how much vacuum your pulling
Blow Off Valve Spring Options
Engine Vacuum Reading Range Spring to Use
-22 through -23 -12 PSI
-18 through -21 -11 PSI
-14 through -17 -9 PSI
-10 through -13 -7 PSI
