Pistons
Old Oct 25, 2008 | 06:25 PM
tibbymat's Avatar
so i finally found some pistons for the tib. now for these ones do i have to bore the engine out or is it same size?
http://www.importperformanceparts.net/impo...ns_hyundai.html
also. connecting rods? i hear theres a length problem with them?> or is it something else? where can i get these?
Old Oct 25, 2008 | 06:44 PM
Those are both oversized. Stock bore may be special order but it is available.
As for rods, you using beta 1 block still? You will need to check clearances and remove matrerial as needed.
Old Oct 25, 2008 | 11:24 PM
Denisst99's Avatar
thta would be the less expensive pistons to get. and they will hold lots of power
get them in a 82.5mm oversize, that way you'll have to start wit ha fresh bored engine,just be sure it will be done properly, round bores, no taper, no oval
for the rods,
you need to grind the bottom of the bore to be sure of clearances if you're using pauters
Old Oct 28, 2008 | 08:44 AM
David Dickson's Avatar
I have OE Bore CP Pistons in my block. Just had to de-glaze the cylinders and I was good to go. I also have the Pauter rods but did not have to clearance anything on my beta2 block. smile.gif
Old Oct 28, 2008 | 10:28 AM
i8acobra's Avatar
Vehicle: '14 Ford F-150
I do believe Jon is selling some pistons/rods...
http://www.rdtiburon.com/index.php?showtopic=29130&hl=
