Need A Smt6 Map
Old Apr 2, 2010 | 06:54 AM
tibs9799's Avatar
I wasnted to see if anyone has a map for the smt6. Im running 440cc injectors, 10 lbs on a t 25 turbo, 3 bar map sensor, and stock maf, no o2s, 255 fuel pump
Old Apr 2, 2010 | 07:34 AM
bmxer's Avatar
Vehicle: 2006 Kia Spectra5
Are you running a secondary injector plate? I have maps for 7, 10 and 13psi. But there for using an Atelierhp secondary injector plate
Pm me with your email if you want them.
Old Apr 2, 2010 | 11:00 AM
supercow's Avatar
dang, I've got a good one for you to start off with. Unfortunently I've lost it and the only place I have it is on the smt6 in the tib.
Runs great with no 02's, the ecu stays completely static and you have full control with just the smt6, and no extra injectors to mess with.
my map is 10-11 psi, 440cc injectors, no o2's, t3 super 60, not running a map sensor though, just stock maf and I have in after the turbo. I'll try to get the laptop hooked up this weekend and get a screenshot of the map. I haven't hooked up to it since I upgraded the laptop to vista a few years ago!
edit:
I went hunting on the server and your in luck!
This should be a good starting point to get it driving, I'm planning on getting mine dyno tuned.
The tib is wired up in the Not-So-Basic-Anymore diagram here.
Old Apr 2, 2010 | 07:20 PM
tibs9799's Avatar
my emaill is t__im@hotmail.com. if u could send me what u have i would be grateful. thank u
Old Apr 2, 2010 | 07:53 PM
bmxer's Avatar
You should have 4 maps. Let me know if they did not arrive.
Old Apr 5, 2010 | 06:48 AM
David Dickson's Avatar
Wait, No O2s? The RD ECU must not be as picky as the GK one. You even unplug a O2 sensor and the GK ECU goes into limp mode.
