turbo on an automatic
Old Jan 18, 2010 | 11:21 AM
Joey's Avatar
Vehicle: 2003 Accent
Default turbo on an automatic
Hey everyone I was wondering if there are negative effects to putting a turbo on an auto? A local speed shop said the stock auto tranny's on an accent are not strong enough to hold under the power of boost and i should really think about doing an auto to manual conversion. What are your thoughts on this? i dont really want to do the conversion but if its the only way i can get my turbo kit to work then I guess I better start looking through salvage yards for a used 5 speed tranny. BangHead.gif
Old Jan 18, 2010 | 12:43 PM
i8acobra's Avatar
Vehicle: '14 Ford F-150
Functionally, turbos actually work better on auto equipped cars. However, most economy cars automatics are extremely weak. You should be fine with a small turbo running low boost, but you'll probably only see about 30 whp from such a setup. With your car being 7 years old, it might be cheaper to sell yours and buy a manual equipped car rather than trying to swap in a manual.
Old Jan 18, 2010 | 01:00 PM
ereeves116's Avatar
Vehicle: 2002 Accent
^I second that. A tranny swap is, while not TOO difficult, a big project.
You will save money if you can bear to part with your car and buy a manual one.
Old Jan 18, 2010 | 02:12 PM
If you can figure out who can do it for you, get a better torque converter and go for it.
Hyundai's automatics themselves are actually very strong and hold power very well but the TC will give out with a large amount of power running through it.
Even stock I wouldn't hesitate to run 175whp through the Accent's Automatic. It might eventually fail, but you won't be breaking them all the time or anything like that.
