Narrowband gauge, wideband sensor
Old Nov 4, 2009 | 07:23 PM
UnnaturallyAspirated's Avatar
Vehicle: 1998 Hyundai Accent
Default Narrowband gauge, wideband sensor
Is it possible to run a narrowband gauge with a wideband o2 sensor??
Reason i ask is cost factor.
UEGO's are so damn expensive.
Old Nov 4, 2009 | 10:12 PM
if cost is a issue get a innovate lc-1 and dont get a guage and run it off a laptop
Old Nov 5, 2009 | 09:44 AM
QUOTE (faithofadragon @ Nov 5 2009, 12:12 AM)
nah. gauge is essential.
not nearly as easy to keep tabs on A/F ratio on a laptop sitting on a passenger seat or floor while driving, as it is to glance at a gauge immediately infront of you.
Old Nov 5, 2009 | 11:48 AM
Old Nov 5, 2009 | 02:00 PM
QUOTE (187sks @ Nov 5 2009, 01:48 PM)
yeah.
and pray the car doesnt blow up between the time i drive it.. and get home to upload the datalog and analyze WHY my car blew up when i could've let off the gas if the gauge was starting to lean out. LOL
Old Nov 5, 2009 | 02:12 PM
Then spend the money to get a wideband and wideband gauge. No other option will give you reliable instant results to a gauge in your field of view.
Old Nov 5, 2009 | 03:58 PM
i8acobra's Avatar
Vehicle: '14 Ford F-150
QUOTE (UnnaturallyAspirated @ Nov 4 2009, 06:23 PM)
Short answer... no.
Old Nov 5, 2009 | 05:40 PM
QUOTE (UnnaturallyAspirated @ Nov 5 2009, 04:00 PM)
yeah.
if its so crucial to not blowing up the motor....doesnt that seem like a good idea to purchase a quality one?
Old Nov 5, 2009 | 06:38 PM
warp21's Avatar
Vehicle: 2000 Hyundai Accent
QUOTE (UnnaturallyAspirated @ Nov 4 2009, 09:23 PM)
I built a very accurate wideband display with a cheap $5 ebay 0-2 VDC four digit display. If you have a programmable wideband, such as the LC1, you can program one of the outputs to read 1 volt = AFR 10-1 and 2 volts AFR 20-1. Then move the decimal on the display to show up between the second and third digit. Works like a charm and reads dead on when compared to the LC1 and tuning software.
Old Nov 5, 2009 | 06:46 PM
warp21's Avatar
Here's a shot of my car at cold idle.
