Turbo Help:Hesitation under load
Old Nov 6, 2009 | 01:09 PM
UnnaturallyAspirated's Avatar
Vehicle: 1998 Hyundai Accent
Default Turbo Help:Hesitation under load
Hey all..
so i was driving to work today... ripped it decently 1-2-3..
1st gear.. great.. i hit 2nd.. stomped on it.. and it's like the car hesitated under full load in bottom of 2nd gear.. then cleared up in 3-400rpm later.
Fuel Filter?
Ignition breakup?
Old Nov 6, 2009 | 01:56 PM
Was the car warmed up? If not that's a common issue with Accents.
Old Nov 6, 2009 | 02:05 PM
QUOTE (187sks @ Nov 6 2009, 03:56 PM)
its dne it before bone cold.. and i figured that out real quick.
but no.. this time the car was fully warmed up after driving for about 15-16 miles.
Old Nov 6, 2009 | 05:27 PM
Fintile's Avatar
its too much fuel...i had the EXACT same issue when I went to the track a year ago...costed me some good times too...
could have hit 15.2 or less at 6 psi but it bogged and hessitated from 2k untill reaching 3,200 rpm then it just took off.
Old Nov 6, 2009 | 06:05 PM
QUOTE (Fintile @ Nov 6 2009, 07:27 PM)
how do i fix it? Lool
ive got a BEGI RRFPR.. but no fuel gauge.. and no instruction manual on how to adjust it.
i know there's a top bolt that is adjustable like a conventional fpr.. and theres a needle valve on one end with a little teenie weenie nut.
http://www.bellengineering.net/product_inf...p;products_id=1
its either that one. or the one for "aftermarket turbo cars" which looks identical.
Old Nov 6, 2009 | 09:38 PM
get a wideband already!!
Old Nov 6, 2009 | 10:00 PM
QUOTE (faithofadragon @ Nov 6 2009, 11:38 PM)
easier said than done.
have to be somewhat careful with spending for the next while.. getting hours cut at work as of next week.. im down 10hrs a week every week.
sucks.
im working on it.
Old Nov 6, 2009 | 10:27 PM
Fintile's Avatar
QUOTE (UnnaturallyAspirated @ Nov 6 2009, 09:00 PM)
sucks.
im working on it.
Dude I have been "working on it" for a year now...get a stand alone and tune it...there's no other way. But yeah raise the boost about 1 psi and see if it helps.
Old Nov 6, 2009 | 10:29 PM
heres a crazy idea then...if you cant completely get a wideband
go to a dyno that has a wideband
then you know how much hp your pushin plus get a reading on what your a/f looks like
the local one here charges like 85 bux
Old Nov 8, 2009 | 02:15 PM
ok. so i took the car for a few spins, WOT top of 1st.. hesitated.. and sounded like shotguns going off, threw a huge cloud of black smoke, and took off like mad.
loud as sh*t.. and im positive if not for my cat.. it would've shot flames.
