High psi pump vs Low psi pump
Old Mar 15, 2010 | 11:26 AM
Goose's Avatar
Vehicle: 2003 Turbo Tib
Default High psi pump vs Low psi pump
Which is more preferred for best atomization? Or are they the same results?
Lets say I needed 500cc/min of WAI (water/alcohol injection) just as an example baseline number.
Would it be better to get a 220psi pump with the appropriate nozzle, or better to get a 150psi pump with the appropriate nozzle?
Given that both pump/nozzle setups supply the same cc/min, would a higher psi pump atomize the WAI better?
Old Mar 15, 2010 | 02:49 PM
Assuming that both systems are equally well designed, the higher pressure system will atomize a liquid better.
