- Coupè (Tiburon) GK 1.6L G4ED Boosting
- Key fobs
- Nitrous fed elantra
- Supercharger tuning advice
- My supercharger build
- looking for a FIC base tune
- turboed elantra need help
- Need info for hard fuel line adapter
- Think these will fit in the car?
- Boosting a 2 litre 2017 elantra
- How much power can a beta autragic take?
- 4 cylinders can be made fast
- Anyone know anything about this build?
- Fuel Pump Connector Issue on Turbo Tiburon
- I want my turbo to sound like this
- The build of the Race Egg
- I love boost weather
- Funny that you can buy turbo kits on Amazon too
- Airram vs no airraim
- This sounds so good
- What makes all BOV's sound different?
- Kfx pnp megasquirt
- Finally will boost my Tib
- What size is your turbo?
- Plug and play for megasquirt?
- Who likes to keep everything from the same company?
- Here ya go n00bs
- Why do people always want to cheap out when going turbo
- What engine to Swap?!?!
- Does chrome hold in heat any?
- a turbo for every cylinder
- Eating oil
- Electronic boost controllers
- I wonder what kind of turbo this is
- Turbo on a high-mileage engine
- Efficiency Islands
- hahahahahaha look at the price
- STI or EVO Injectors
- Veloster turbo vs Accent GDI engine?
- Turbo Donuts
- Stock manifolds
- Any V6 Haltech users?
- Turbo or supercharger?
- What are the advantages to having a top mount turbo?
- SICK Twincharged Beta Powered Accent!!
- SpoolinShark's turbo build
- Are Water to Air ICs less efficient than Air to Air?
- What's good fuel line these days?
- My new turbo heat shield
- Volvo found a way to handle with TURBO LAG
- Turbo Heat Shields
- 2 different tunes
- How to bore intake manifold?
- Godspeed's 70/68 T4 turbo
- do sandwich plates work
- External Wastegates
- wrapping exhaust VS ceramic coating
- magnetic balancing
- smt6 calibration
- Opinions on injector brands
- How does the stock ECU handle bigger injectors?
- Adjusting factory wastegate
- decompression gaskets
- TurboXS or Forge?
- Turbo Tibby
- map with smt6
- Turbo cars and winter
- Blowoff valves
- A real working electric supercharger
- Does higher compression spool a turbo at a lower engine speed?
- $2000 upgrade
- Mother of god
- Time to buy a new blow off valve
- gk ecu swap
- how do you know if you have a bad turbo??
- Trying to find a tuner
- Getting closer to boost season!
- Best way to explain high boost on stock internals
- Brace Yourselves: The Next Generation Of Hybrid Turbo Is Coming
- 2004 Sonata 2.4L Turbo ECU
- Easy way to tell the difference between these 2 things
- fuel pressure regulators
- Anything like a procharger for us?
- What happens if your intercooler is too big
- Smt6 help
- Help with aem fic
- I feel like this isnt a very efficient set up
- Who has the biggest turbo?
- Cheap turbo setup
- Boost control
- dyno for 6psi?
- Any 400+ horsepower cars driving around?
- Polished turbo housing
- Exclusive: Hyundai 3.3 Turbo GDi V6 Engine
- Performance Hyundai turbo
- Aem fic base tune
- Intercoolers FAQ
- Strange turbo set up
- Testing Flow of Intercoolers
- Stainless Steel Manifolds
- Hyundai turbocharger selection for help?
- Turbo vs. non-turbo
- balance a turbo
- Intercooler efficiency vs. flow
- Fuel problems
- Boost timing retard versus octane ratio
- Is seafoam bad turbo engines?
- Air filter?
- Id1000 injector dynamics
- T3 to t4 adapter
- alice6's build
- BOV and Wastegate's
- Avoiding turbo lag
- where do you get your AN fittings?
- What Should IAT Be At Cruise?
- Cleaning a used turbo
- Painting your intercooler black mythbusted
- plug gap
- Piston choices
- Anyone installed bigger than 3" piping?
- Oil feed and return question
- $4,000 enough for a turbo build?
- What boost psi requires an intercooler
- $190 turbo?
- 2.0l engine
- Internal Wastegates
- cool depiction of how the new F1 engines work
- LOL I wanna do this to my BOV
- compressor wheels
- journal bearings or ceramic bearings
- Fuel restriction past 5psi
- Turbo Blanket Sizing
- At what point is too much HP too much
- Riddle Me This
- oil lines
- turbo oil leak
- Aftermarket Styling for 2003 Hyundai Getz
- My latest turbo project
- turbo sonata 3.3
- just a tad off topic
- Water Cool Wastgate
- Top mount T4
- is a smaller water cooled oil cooler better than a traditional air style?
- apexi tuning
- What supercharger is this?
- Wastegate Sizing
- Better to build and boost a beta1 or beta2 ?
- tubular manifolds
- Expensive Controller
- Best way to flare 3" cold side pipe
- Turbo Engine Build Help
- Inconsistent afr at WOT (AEM fic)
- AEM F/IC
- Jim Wolf Disco Potato
- Electric superchargers are getting expensive
- 1bar map to 3 bar
- Motor Mounts
- 1.8 pistons/rods
- Frequency of spark plug change
- Certain position for BOV or Wastegate?
- Whats the latest news of the twin engine tibby
- Good AFR to aim for at WOT
- Is a turbo timer a good investment?
- Which is more cost effective for a 3.8 Genesis?
- megasquirt
- how to keep the heat down??
- Supercharger for $179
- Siemens ECU vs Bosch ECU
- safc install
- New intercooler! Now should I wrap the IC pipes?
- 60 pounds of boost!
- I want a supercharger really bad
- Turbo for 02 1.6L rally racer
- LMAO!
- IC PIPING
- CP Pistons
- How much heat can silicone couplers handle?
- Solid motor mounts be ok on a turbo engine???
- SMT piggyback Base Map
- Compression testers?
- Turbo question
- Re-flashing the EF Sonata 2.4 ECU...done ;).
- Ported heads on turbo bulild- Good idea or not worth it?
- car wont idle after tune
- Crushed bent exhaust question
- AEM F/IC MAF simulation
- What dictates whether you need an oil restrictor for your turbo?
- Are there any compound turbo users on here?
- The best Intercooler CORES in your opinion?
- T3 to T4 adapters?
- Anyone have any new cool projects for this spring?
- This made me laugh
- Consumer Reports: Turbos fall short
- in need of turbo education
- Is this intercooler crap?
- thermostat question
- I have a couple quick and simple questions about mega squirt
- Bad to start car in the cold
- Turbo Tiburon 2.0
- what do you guys think?
- turbo questions
- downpipe fr t3t4
- AEM's new Fail Safe Gauge
- holset turbo
- help with boost gauge and oil return
- WTF is brake boosting?
- What does HA think about this turbo for a Beta II
- Thinking about switching my BOVs
- Turbo reliability (turbos themselves not engines)
- Detailing the FMIC?
- Oil-Less Turbos
- Boost tap location???
- Anyone regret boosting FWD
- kspec.com 290cc Injector Impedance
- need turbo help!! turbo noob here
- Godspeed wastegates
- intercooler sizing
- Favorite oil pressure gauge
- how nesccary are tranny coolers on auto turbos?
- good ball bearing turbo?
- How do you know what A/R you need ?
- What intercooler is best to run with a T3/T4 Hybrid Turbo?
- BOV placement matter?
- Turbo,how its made.
- Would this be a good turbo for my car?
- Whats a synchronic bov?
- Boost vs Boost/Vacuum Gage
- Oil in intercooler pipes
- Hit the dyno,upped the boost to 23 psi and....
- Trying to find that perfect turbo (and failing brilliant)
- what is the difference between T4 and T04
- Ever installed a turbo on something other than your car?
- Factory Tiburon ignition map
- larger primary injectors
- TD05 Oil Feed
- Superchargers
- Its not illegal, its just looked down upon like masturbating on an airplane - Turbo Chat
- DIY Boost Leak Tester
- Gas mileage
- Heat retention of carbon fiber
- to rebuild or to not rebuild
- Accent Beta Turbo (Scaryed of more boost?)
- TD025
- in major need of a downpipe
- My car is driving me nuts, turbo questions, etc
- Turbonetics Hurricane Series?
- hyundai racetrack
- Forgive my noobiness
- Maybe a new thread for cold side
- are all V band clamps the same?
