gk ecu swap
Old Sep 21, 2015 | 09:45 PM
fronkkillsit's Avatar
Default gk ecu swap
Is it possible? Could I swap the ecu and wiring harness from a gk to my rd2? I don't care about how much work its gonna be or the expense. If its possible I'm going to do it. Seoulful has a reflash for those ecus so I'm trying to go that route.
Old Sep 21, 2015 | 11:00 PM
tibbytib's Avatar
Not sure what you're going for here. You have a beta ii swap? If you're just looking at getting the reflash, I'd say you need to research more. Canned tunes are not typically the best. I would seriously consider simply installing a quality piggyback. That will get you way further then a reflash. If you know anyone who can tune, you could go with a stand alone as well.
But throwing money and time in doing a harness swap just to get a half assed canned tune reflash is not a good way to go IMO.
Old Sep 22, 2015 | 06:09 AM
Anything is possible with money and time. However, is it the right thing to do? Not one bit! It'll be the biggest challenge and pain in the ass project you will ever do, and more than likely will leave you with an undrivable car and a world of frustration. The amount of time and money spent doing it could be better used on something else, like an actual turbo set up with a piggyback, which will give you WAY more power, WAY less of a headache, and be a more efficient.
Old Sep 22, 2015 | 07:20 AM
JonGTR's Avatar
It is possible, but not worth the effort. There are different sensors on the motor that would need to be swapped. And the ECU controls more than just the motor.
Old Sep 22, 2015 | 09:31 AM
Tibbi's Avatar
Originally Posted by Visionz
...with a piggyback, which will give you WAY more power, WAY less of a headache, and be a more efficient.
What did I say on booker?
Piggyback and fahgatabouteet
