$190 turbo?
Old Apr 1, 2014 | 04:55 PM
hprockets's Avatar
Vehicle: 2009 Hyundai Sonata
Default $190 turbo?
http://www.ebay.com/itm/GT45-T4-T04B...-/200908420867
[ebay]200908420867[/ebay]
T4 TO4B GT45 Turbocharger
FOR auction is T4 turbocharger Only, Oil line Kit included!
APPLICATION
Universal, Fits all cars and trucks
DESCRIPTION
3" Inlet Diameter
2" Outlet Diameter
Journal Bearing - Wet Float Type
T4 Flange
Oil Lube/Cool
Compressor Wheel
0.50 A/R Cold Side
Ind: 54.06 mm
Exd: 69.91 mm
Trim:
Turbine Wheel
1.15 AR divided housing
Ind: 73.16 mm
Exd: 64.16 mm
Trim: 76.9
Oil Feed Line kit Specs
Stainless Braided-synthetic rubber hose, temperature rating: -40 + 300 degrees F, with female swivel both ends size 4.
Size: -4 AN, ID: 0.22, OD: 0.44, Length: 14.5"
1/8" NPT to -4 AN, 90 degree adaptor
3 way 1/8" NPT adaptor
Size: -10 AN, ID: 0.22, OD: 0.44, Length: 17"
2 x straight swivel-seal style hose ends, size AN -10
Oil return line flange
straight buck head , -10
2 x stat o seals 7/8"
-10 nut
GET FULL OIL LINE KIT FOR $80 EXTRA !! FREE SHIPPING
35 PSI Peak Power Performance Output Capability
CNC Machined Flanges
Turbo Comes With Its Own Serial Number, WELL BALANCED.
Is it junk?
Old Apr 1, 2014 | 07:06 PM
Its probably made of plastic lol
Old Apr 1, 2014 | 07:52 PM
pas1216's Avatar
Vehicle: 1991 Impulse RS
you usually get what you pay for. I would expect that thing to boost 2 or 3 times before exploding.
Old Apr 1, 2014 | 09:42 PM
Tibbi's Avatar
Um, for a GT45?
3" Inlet Diameter
2" Outlet Diameter
That doesn't seem like the specs for a GT45
What the hell do you want to put something that large into?
Old Apr 2, 2014 | 06:33 AM
If you want a cheap turbo contact turbosocks he sells some pretty decent ching chong turbos and hasn't had any quality issues iirc
