- Plugs Or Fuel Pump?
- Smt6 Owners
- Radiators For Xtreme Moded Cars
- Stock Beta I
- Wideband Question
- 50 Turbonetics Vs Gt30r
- Safc 2 Na Points
- Safc-2 Opinion
- Little Update
- Who Has A Wideband O2 Gauge
- Egt Readings?
- Arp Stud Specs
- Updates On My Car
- Vr6 Swap?
- Best Turbo
- What Turbo Book Besides Max Boost To Read?
- 5th Injector
- Shark Racing
- Msd Disii Wiring Diagram?
- Why Not A 50 Shot Of O2?
- Greddy E-manage Or Hks F-con Sz C
- I Need A New 2.5bar Map And A Resistor.. Help Me!
- Project Under Way!
- Idle Problem
- Going Boosted
- Sr20det Swap From Beta Uno
- Srt4 Turbo
- I Wanna Boost
- What Is The Easiest, Cheapest Way To...
- turbo help low rpm stalling
- A Few Questions
- Who Put Fans In Front Of The Radiator?
- Oil Return Help
- Advise Required On Radiator Heat Shield Matarials Etc
- Wideband With Standalone
- Still Havin Issues
- Ngm Making A I4 Supercharger W Ice Box!
- Finally Got My Turbo Kit!
- Quick Update
- My Future Turbo Setup
- Obd Reading High Temp
- Maf To Map Conversion
- Safc2 And Boost Under 8psi
- Electric Problems, Fire, Oh My....
- Good Bye My T3
- Turbo Porting/polishing
- Oh No....
- Boost...boost...boost...
- Setting Up Emanage
- 2004 Tiburon With Alpine T/c
- Compressed Air Boost
- Turbo,super,na?!?......help A Newb?
- Ecu Reflashing
- Boost spikes
- Turbo VS. Supercharger?
- Evo Turbo Manifold
- Few Questions
- Virginia State Inspection
- Turbo
- Dsm Turbo Manifold
- Za's 200-400kw Turbo/nos Tib
- Turbo Timer And E-management For Rd1
- I Just Got My Hands On An Msd Ignition
- Ecm Pinout
- Ha, First Major Issue
- Turbo Project In Full Swing
- Will Not Idle....
- Wideband Question
- Tibs Finally Boosted (like 6 Months Ago)
- Different Spot For Oil?
- Oil Everywhere!
- Where To Go To Get A Turbo Installed Properly
- Supercharger + Blowoff... How?
- Map Sensor Install On Custom Turbo Set Up
- Turbo/supercharger
- 1.8L Block Buildup
- Oil Pressure
- Oil Leak Question
- Some Major News On My Car
- Engine Management
- Time To Pressurize A Line?
- Turbo Or Supercharger
- Help ? The Right Spark Plugs For A Boosted Tib ?
- Experience With Profec E-01
- Questions About Sensor Readings..
- Turbo Tibs
- Another Head Spacer Thread.
- Boost With Decomp. Plate
- Standalone
- Dynoed And Tuned At 20psi **update**
- Last Week Of My Life
- Speed Factor Down Pipe Question
- Omg Oil Pan Removal Was.....
- New Dyno Numbers
- Dual Wastegates?
- Charge Pipe "lips" On Ends
- Questions About Wideband O2 Sensors
- Lean Situation
- Reinforcement With Turbo
- Definitive Quaife Lsd Thread
- An Idea For Oil Return Line
- Ever Hear Of Oil Seals Going Bad From Sitting
- finally got the drag vids on the web ,01 turbo beta
- Oil Feed Source
- Oil Leak.
- Obd Scanner And Some Other Questions
- Turbo Internal Or External Wastegate?
- Is This A Good Turbo Kit?
- Turbo Cams And Stock Springs?
- Maf Problem
- Smt6
- Msd Ignition
- Bad Hla (lifters)
- 16g Manifold
- Alpine Experience
- Fuel Delivery Problem
- Secondary Fuel Rail Guys Come Right Now!
- 8 Psi Ignition Timing?
- Alpine Update
- 7.7-1 Pistons + Rods?
- Turbo Kit
- N/a Questions
- Aem Fpr
- "good" 8.5:1 Head Gaskets On Ebay
- Horsepower Gain Calculator From Turbo Or Supercharger
- Turbo Vacuum Line Size?
- Little Oil Return Line Leak
- Fuel Rail Adapter
- Iat Sensor
- A Little Update
- Thinkin Of Boosting The Tib.
- Turbocharger Died
- Standalone Systems
- Accent Beta 2 N/a Project
- Intake Manifold ('s)
- Lower Compression Head Gasket
- Fully Rebuilt Head?
- Cost Of This Turbo Set Up?
- Emanage Settings...?
- Help! Sputtering Turbo Problem!
- Turbo Mounted
- Wiseco Pistons=2.1?
- Elantra-auto Ecu Same?
- Fuel Management For Turbo
- Turbo Cams
- Emanage Base Settings For 2.0? 2.5bar Map Sensor Q As Well...
- Tial Wastegate Install
- Idle Control
- Another Egt Probe Location Question
- Head 97- 99
- Megasquirt Success?
- Smt 6 Maps
- Look What I Did Today!
- Fuel: Returnless To A Return System
- Aftermarket Head
- Oil Feed Line Oil Flow Restrictor?
- Oil Return Line Length
- Turbo Rods And Turbo Questions.
- Alternative To Supercharging...
- Shark Racing Bov
- Smt6 With Secondary Fuel Rail
- Electronic Supercharger....
- Blow Off Valve
- Engine Swapping
- T3 Super 60 Turbo Shaft Play
- Turbo Manifold
- 2001 To 2003 Im Swap
- Turbo'ing My Scoupe With Beta Engine
- My Turbo Manifold...viper Get In Here
- 1.8 To 2.0 N/a
- Exhaust Setup For My Turbo Project
- Your Basic Turbo Grocery List
- T3 Super 60 Turbo Question
- Clutch And Flywheel Suggestions
- Smt6
- Headgasket Torque
- T3/t4 Turbo Questions
- Need Some More Spark?
- Bought 2.0 Engine For 50 Bucks 40k Miles
- Pistons
- 2.0 Beta1 X3accent, A Compressor Wanted!
- Need Help With E-manage Ultimate?
- Turbo Ecu Needed
- Where Can I Get A Turbo Head Gasket
- Some Turbo Advice
- What Should I Use To Break In A Fresh Engine
- Turbo With Auto
- Bbtb?
- Downpipe
- Stupid Bolts! - Turbo Problem
- F350 Turbo Install
- My Dyno Sheet..
- Anyone Misfiring With High Boost?
- Book For Tuning?
- Apexi Turbo Timer With Afr Gauge
- Question About
- Crankshaft
- Injectors
- Sure Would Be Cool
- Supercharging Our Tibs
- Things I Need To Run T3/t4 Turbo. Properly
- Question Reguarding A/f Ratio
- Rebuilding Engine
- Vtec Tibby?
- Where Can I Get Drag Axles?
- Arp Head Studs With Boosted Application
- Emanage Ultimate Help - Please - Odd Problem (2.0t Gk Tib)
- Fuel Problem.. Not Sure If Boost Related..
- Engine/transmission Rebuild
- Msd Coil Pack
- Pulled Back Lean By The Ecu....arg
- Prs4
- Why Do You Need A Second Rail? - Smt Experts Please!
- Boom!
- Question About Fuel When Boosting
- Perfect Power Woes
- Dsm Turbo Setup On 2000 Tiburon
- Just Finished Up My Injector Smt-6 Install On Sunday
- Possible New Plug And Play Ecu In The Horizon!
- Some Tuning Question?
- Clutch, Flywheel, And Cam Gears
- Adjustable Intake Cam Sprocket
- Stupid Oil Press. Gauge.. Hook Up To Head?
- Just curious....
- Greddy Emanage Ultimate
- Standalone/ecu For Dummies Thread
- Automatic Beta II powered APE Drag Tiburon
- Tigerlily Cast Pistons
- Map Sensor Headache
- Boost Problem
- Where Can U Get
- Ecm Help?
- Apexi Safc Ii
- I Want To Go Turbo
- Fuel Pump Whining
- Ecu?
- Final Turbo Kits Pricing Etc
- Turbos?
- Dyno Tuning On Sat With Smt-6
- Intercooler Questions
- Diy Turbo
- $4500, I Think I Need A Turbo
- Turbo kit
- Couple Smt-6 Questions
- Cooling Idea
- 14b Boost Threshold?
- Possible Turbo Setup Pricing
- Need Help From Smart People For Boost Project!
- Kspec Turbo Kit
- Air Fuel Ratio With Boost
