Emanage Base Settings For 2.0? 2.5bar Map Sensor Q As Well...
I'm begining to wonder if the shop that originally installed my eManage even setup the base settings correctly...
I searched here and hp.com and haven't found a single post stating what the base settings are (engine code, etc...)
The settings put in there by the shop just seem a little off to me, I'm wondering if anyone can point me in the right direction where I can find these settings?
Also, I just changed the MAP Sensor from stock to 2.5bar -- I clamped the MAP Sensor to 4.40v and it's drivable but bogs when it hits boost, now the eManage is using the GReddy MAP Sensor, but I guess the ECU is still using the stock MAP, I'm not even sure if "clamping" it through the eManage is working correctly... though if I clamp it to 4.46v across the board, rev's hang and it's really not drivable, if I do 0.00v across the board, it's drivable, but barely...
If anyone has any thoughts on this please let me know.
