Turbo Timer And E-management For Rd1
the emanage ultimate will work, but i would just stick with the emanage blue.. for the price of the ultimate, you misewell go with a cheap standalone setup.
the ultimate does have a MAF removal which is a very cool option, and basically will make your car as close to standalone as you can get.. there are a ton more options with it also, but its almost 2X the price of emanage blue.
i would go with a emanage blue, profec e-01, dual fuel rail setup. you will be able to tune your car from the inside at all times, and be able to monitor vital sensors. the profec e-01 is also a electronic boost controller, and comes with a MAP sensor for boost.
i think there is one member on here running standalone AND the ultimate, but i dont know of anyone running on a stock ECU and ultimate.. the setup would be just like emanage blue, but would have alot more options, and sensor eliminations, but i don't think it would be worth it for the price.
if you need anything more, just let me know. i hope most of that cleared it up for ya..
i am using a greddy turbo timer, and its not wired correctly, so i couldn't tell you if it works properly. any turbo timer will work though.
