Help ? The Right Spark Plugs For A Boosted Tib ?
Hey,
I have been told that the right plugs for my Turbo'd Tib are NGK BCPR7ES and apparently the gap should be .45 - .5mm so the spark does not get blown away by the boost.
The plugs that are in the car are NGK BCPR6ET ( Multi Terminal - so you can't set the gap)
I'm running one step colder (fyi, if you can't find the list of steps of coldness for the Tib, then get plugs for a mid 90's Subaru Legacy (any motor), they are one step colder).
I'm running a .035 gap. .040 is closer to the stock number.
QUOTE (whitefang @ Jan 29 2007, 05:30 AM)
NGK BCPR7ES
Yes that is the correct part # as I have about 3-4 boxes with 10 each sitting here, I change my plugs after every run so I go through a lot of plugs. cool.gif
Java you can run either one the only difference between the 2 part numbers is one has a slightly taller porcelain body.
And for the gaps it will vary between car to car, you will just have to adjust it until you don't blow the spark out.
^WTF??? your running boost and want to use them plugs http://www.globaldenso.com/PLUG/cros...e/1023_01.html
I use HKS R50 that = heat range of 10 and they have the right kind of tip if you use anything else it could
1.melt off
2.fall off
3.fubar your pistion
now if you want to use other kind thats fine too.. but i am letting you all know that this is what we use here and dont wine about the price i payed 200 USD for my plugs
HKS R50 PRO RACING PLUGS
10= heavy boost 400+
9= winter time
8=eveyone up to 350whp
1.melt off
2.fall off
9= winter time
