Tial Wastegate Install
Old Nov 20, 2006 | 08:26 PM
dvanderk's Avatar
I have a question, the vac. routing for the Tial wastegate....
Do you need the "vent" as the instructions say between the boost controller and the top of the wastegate?
Im really confused about this...
Old Nov 20, 2006 | 08:46 PM
i am not using the vent.. its just open and everything is working fine.. i think some cars use it, and others dont, im not exactly sure.. i have never seen it hooked up on a car before.
heres it on my car..
EDIT: i dont have any pics.. 02.gif
Old Nov 21, 2006 | 05:56 AM
Mad_john's Avatar
what ever you do not connect , your waste gate to any vacum line.. only your charge pipe
Old Nov 21, 2006 | 02:33 PM
Viper966's Avatar
yes, you connect the port on the side of your wastegate to the charge piping (typically the turbo outlet) the reason for this is that there is a serious delay between when the turbo starts spooling and the vacuum signal reaches the wastegate this can cause boost spikes
the top port on teh wastegate is only used when a boost controller is run, you use the boost controller to push the diagphram the other way against the one on the side to hold it open/closed
