Turbo Mounted
Old Nov 26, 2006 | 12:23 PM
wolfinsheepsclothing's Avatar
instead of having the intake piping go all the way from the turbo on my drivers side to the passengers side to go to the intercooler.. do you think i can fit my 50trim turbonetics turbo the other way so i have my downpipe towards the drivers side and the outlet of hte turbo closer to the intercooler? ive been looking at pics but i cant get a good look at some of them..
Old Nov 26, 2006 | 12:28 PM
doubt it. the alternator is close enough as is.
Old Nov 26, 2006 | 12:29 PM
12SecRD's Avatar
You will have ground clearence issues with a 3" downpipe/exhaust because the oil pan.
Old Nov 26, 2006 | 12:51 PM
hamhead's Avatar
Ye, I'm pretty sure the oil pan will get in the way. You could always make/get someone to make an oil pan that would get around that, but its probably more trouble than its worth unless you want it that way.
Old Nov 26, 2006 | 12:58 PM
i just hate how i have to run my piping along my radiator to my intercooler.. it jsut seems that there should be a better way
Old Nov 26, 2006 | 02:34 PM
JonGTR's Avatar
You're talking about 8" more of straight piping. Not something to lose sleep over.
Old Nov 26, 2006 | 02:47 PM
no but its something to loose horsepower to... there is so many unneccesary 90 degree bends in a turbo system that just kills airflow...
Old Nov 26, 2006 | 03:29 PM
Tibminn's Avatar
air flow is made a lot less significant by the turbo since it compresses the air in the pipes rather than it "flowing" through. does that make sense?
shorter piping reduces lag and i guess then adds hp a bit earlier, but as JonGTR said, losing 8" will not be that significant
Old Nov 26, 2006 | 03:46 PM
i have hte winter ahead of me.. my tiburon is not my daily driver, and i know that much less tubing is probaly not even gunna get me 1 hp but if i start letting little stuff go like that, then i could be robbing myself of some serious hp numbers... i want my car the best it can be, not "oh eyah its kinda fast wiht a turbo".... i dont wanna buy any part and slap it on becuase it says "GUARENTEED 40 HP GAIN!!!" i want to research the amount of spark i need, the minimum amount of fuel i need, and my temp and restrictions in my air flow... thats the reason i recently joined this forum, to get the most out of my car
QUOTE (TibMinn @ Nov 26 2006, 05:29 PM)
and hte way your talking, if i want good airflow all i have to do is but a turbo on it and not worry about cam duration or head porting or anyhting liek that........... sorry if im sounding like a dick but i just want my car to be the best it can and not done sh!tty
every bit of small detail will definatly make your car
Old Nov 26, 2006 | 04:06 PM
zoned019's Avatar
Vehicle: 97 Tib
isn't this thread about the piping? you asked the piping question, you got your answer. now it's your call on what you want to do, make a custom oil pan, or simply use 8 more inches of pipe.
i think you're getting ahead of yourself talking about adding cams and stuff.
1 step, 1 thread at a time bro.
and please start using the spellcheck feature, i hate reading things that looked like a drunk person typed them.
