8 Psi Ignition Timing?
From: York. About 2hrs from Philly and 4 hours from Pittsburgh
Is there any need to wire up my smt6 for ignition timing if I'm only running 8 psi? The whole fuel system is modified (fpr, pump, injectors).
just running 12:1 with 93 octane is plenty protection against detonation at 8 pounds, although the plugs wont hurt
IF your doing the wiring anyway, its only a few more wires and itll save you from having to rip it apart later, if you wire it in, you can just leave the ignition map unaltered for now if you just dont want to mess with it.
