Engine/transmission Rebuild
Old Sep 11, 2006 | 11:36 AM
yamaha's Avatar
Vehicle: 2000 Hyundai Elantra
As many of you saw in my previous post for winter projects. I have decided to go a totally different route for my engine/transmission setup. After talking to a person at Level10, it is way cheaper and more effective to get the manual transmission swap and rebuild then engine from there. Level10 wanted 3,200 dollars for a bulletproof transmission, which I can complete the auto/manual swap and get my engine built for aroud that. After discussing with Faith, he suggested the following:
Copper Headgasket
Block:
overbore
vac cleaning
magnaflux
checking the deck
deburring
red glyphol
Pistons:
Wiseco forged low compression
Stock Rods:
Shotpeened
Head:
Porting/Polish
Cams
New springs/retainers
Polish valves.
Manual Transmisison Swap:
Clutch
Flywheel
I am asking the forum members for other suggestions and their opinions. I am shooting for around 300 horsepower, which the T28 can handle, and I think I will be able to accomplish with this setup.
Thanks,
Sean
Old Sep 11, 2006 | 02:29 PM
hamhead's Avatar
300whp will be tough for that lil T28, but other than that I think its a good idea to go with the manual tranny and getting the engine stronger. The Beta manual tranny is very sturdy when abused properly.
Old Sep 11, 2006 | 04:59 PM
Denisst99's Avatar
the stock head gasket will hold up quite fine for those HP level..
i've never been a big fan of cooper gasket , but that was before the newer ones with imbedded silicones rings,thinghs might be better now...
Old Sep 11, 2006 | 05:03 PM
denis i found a place that will do a copper gasket for cheaper than the stock one from hyundai...
well jongtr found it (nana.gif)
Old Sep 11, 2006 | 09:50 PM
yamaha's Avatar
Another route I may be taking if I decide not to build my engine is this:
Fully built engine, talked him down to 2,100 for the following:
2.0L Fully b\Built Motor
-Wiseco pistons
-Pauter rods
-port/polished head
-balanced, clearanced, deburred, trued, cleaned, etc
-perfect for a highly tuned turbo setup.
-this block is fully built by CGM motorsports
Old Sep 12, 2006 | 03:18 PM
renante's Avatar
recommend to buy the cgm motorsports full built engine.
provided that they have excellent reputation for engine rebuilds.
3mm composite cooper head gasket cracked at 20psi 335 hp.
I eventually found out afterwards, that they are rated for 7psi to 14psi.
i've gone the full rebuild with a Metal Gasket for the cylinder head.
supplier. http://www.importperformanceparts.net/
metal gaskets are rated for 20psi plus.
i'm not sure why anyone, would keep mentioning that stock gaskets can handle 300hp+.
Unless its racing workshops in Korea that can afford engine rebuilds every 6-12months.
for a t28 turbo.
gt2540, gt2871r, gt3076r.
my garrett gt3076r is rated at 500hp.
With the new engine rebuild and modified manifold, car is now spooling under 3000rpm.
I haven't tested the max hp yet, as I'm running in the engine for the next 2-3 weeks.
Old Sep 12, 2006 | 03:21 PM
QUOTE (renante @ Sep 12 2006, 09:18 PM)
well thats not a gasket thats a head spacer a copper gasket thats not a spacer will hold more power
also
we have metal headgaskets from the factory...hence why they will hold to 300 BUT YOU NEED PISTONS not a spacer
Old Sep 12, 2006 | 06:18 PM
Denisst99's Avatar
trust me,
an OEM gasket with a CORRECTLY resurfaced head and block will hold quite a good amount of power
BTW head studs at this point aren't even an option...
Old Sep 12, 2006 | 07:20 PM
Jay-M's Avatar
Vehicle: 01 Tiburon
QUOTE (yamaha @ Sep 11 2006, 09:50 PM)
That's Maierapril's built engine right? sounds like a good buy!!!
oh yeah, are you going to get colin's auto to manual swap parts or do you have something else in mind?
Old Sep 12, 2006 | 10:04 PM
yamaha's Avatar
faith will be helping me get parts for the sway. I talked Maier down to 2100 if I come down to pick it up. Suggestions on pricing?
