Question Reguarding A/f Ratio
Old Sep 21, 2006 | 04:26 PM
dvanderk's Avatar
Right now, my setup is running at 13.5 psi with a stable 11.8 a/f ratio from 2,800rpm to 6,500rpm. Now, if I lean out the car to 12.5 a/f ratio is that considered safe for this boost?
If not, could I atleast lean out the application at 12.5 from 2,800rpm-4,000rpm then from 4,000rpm to 6,500 set it to 11.5?
Thanks,
Derek
Old Sep 21, 2006 | 05:26 PM
tanc's Avatar
Vehicle: 1997 Tiburon
First of all man you have to give us more information.
What set up are you running? Turbo, fuel, ignition, etc ...13.5 psi so? Are you puttin 400who with 13.5 psi or 150whp.....
What fuel management are you using?
Internals?
Why do you want to do this?
Old Sep 21, 2006 | 06:18 PM
dvanderk's Avatar
Here's a link to the stats of my setup with pictures:
http://www.newtiburon.com/forums/showthrea...hlight=dvanderk
That should provide enough info. What are your opinions on the a/f situation.
