- Shark Racing Turbo
- Fuel Management For Turbo
- Hybrid Intake Manifold
- Auto Transmission Holding Up With Turbo
- Sce Head Gaskets
- 1.8/1.8 Pistons And Rods
- Charge Pipes
- Turbo Kit?
- Turbo Kit For Rd1
- New Lsd, Not Tru Lsd, But Looks Ok
- Hooking Up Bov. Intake Mani Or Elsewhere?
- Multilayer Steel Gaskets.
- Fuel Pressure Acting Goofy.
- In Market For New Gauges
- 1st Boosted Dyno Today
- Supercharger At Ebay
- Dsm Injectors
- My Turbo Project Q&a Thread
- Exhaust Gas Temperature
- Turbo An 01
- N/a Power!
- Turbo Flowmap Plotter
- How To Choose Injector Size?
- Need A Smt Map, Get It Here.
- These The Injectors?
- Shark Racing Turbo Kit
- Fuel Injectors
- Quick Dyno Video
- Crappy Head Design Pissed Off.................
- T3 Internal Gate Problem
- Vacuum Lines
- Map Ecu
- Cars Fine But..
- First Megasquirt Powered Tiburon Ever Is Alive Hahahaha
- Question For People With Emanage
- Round 5000
- Belt Wont Fit
- Boost And Nitro
- Lower Compression Head For Turbo?
- Best Intercooler Dimensions / Bar Plate...opinions Needed
- Is The T3/t4 All There Is?
- Intercooler
- Turbo Build Tips
- Fuel Pump/ecu/fuel Injectors..
- Catch Can, Pcv Setup
- 2 Blow Off Valves Instead Of 1
- Who's Interested In A "turbo Intake Manifold"?
- Intake On Turbo
- Help With Ecu
- Need A Down Pipe For My Turbo
- 2 Questions Reguarding Forced Induction
- Engine Build Complete - Auto Turbo
- Gt45 Ball Bearing Turbo....too Big?
- O Misfire Why Do You Haunt Me?
- Maf Position On Turboed Cars
- My Us Spec 300whp Daily Driver/racer
- Problem
- Turbo Time
- Gettting Boosted My Car
- Turbo Kit, Switch Engine?
- Fast Idle Problem
- My Diy Turbo Kit
- Turbo Project
- High Comp Pistons
- Supercow's Turbo Project In The Works!
- Cel Codes
- Need Some Input On Power Wires.
- Update: Finally Got Unlazy, And Threw On New Snail
- Turbo Install Finished Pics
- Pcv Valve + Boost
- Wiring The Apexi Rsm Meter, Dashboard Taco.
- Took The Week Off Of Work To Do Finish The Car (pics)
- Got Boost?
- Smt6 Instalation Need Help Asap
- Need Return Line Flange For T3/t40e Turbo.
- Perfect Power Smt-6 Wiring Diagrams Guide
- For Those Of You Who've Made Your Own Aluminum Charge Pipes
- 900 HP Beta
- 900 Hp Beta
- Modified Lsd.
- Tapping Oil Pan, Question.
- Fpr Help Please
- Temp Sensor Location
- Megasquirt
- Crazy Idea
- Turboing
- Throwout Bearing?
- Head Gasket Issue With Overbore
- Boosting With Race Gas
- Rdtiburon Bolt-on Turbo Kit
- Oil Pressure Problem Urgent!
- Interest In Me Making Turbo Kits?
- Cost Ratio Basics For Turbo Setups
- More Acceleration And More Hp?
- Turbo Kit
- Egt Q
- Yamaha's Turbage Thread (pictures)
- Is Turboing Worth It?
- Sandwich Plate...should I Get One
- Cams
- Wiseco Forged Pistons 97-00 Beta 1 To Beta 2?
- Guess What I Got Today?
- Maf Under Pressure Boost
- HELP!!!
- Help!
- Test Fit Of Gt35r Pics (no56k)
- Ecu Wiring Help
- Turbo And Natural Gas
- Will This FPR Work With Our Cars?
- Pics Of My New Parts **no56k**
- High Hp = ?# Injectors
- New Setup
- Nice!
- Water Line Feed For Turbo.
- Who's Boosted?
- Turbo Timers.. What Are You Using?
- Fpr Is It Needed
- What Do You Think About This Boost Controller?
- Wastegates..
- Turbo Install + Tuning.. How Much?!
- Guys With Turbo And Jethot
- Pistons And Rods
- 2g Exhaust Manifold
- New Intake Manifold
- Check This Intake Manifold Out...
- Shark Racing Cams How Much And What Profile?
- How Can I Put Second Fuel Rail?
- Can I Regulate The Oil Pressure? Or Put New Oil Pump?
- Going Turbo....
- Turbo Products Of Choice
- Boost From The Garrett Gt3076r.
- Boost Gauge Mounted
- Turbo Install Questions?
- Seoulfulracing Turbo Kit
- Oil Line Fittings
- Turbo Questions
- I Need To Change My Map Sensor?
- Toning Down My Turbo Kit Again :(
- Switching Fans
- Smt-6 Wiring Help
- Turbo Project Started.
- DaytonaTibby's turbo setup
- Is A Garret Gt-22 Turbo Too Small
- Places To Tap The Oil Pan.
- Hi Comp Pistons
- Charge Pipe Question
- Check This Out!
- Found My Turbo :) Finally
- Bolt On Products For The Turbo.
- Someone Have Wideband 02 Sensor And Have Tune By Itself?
- First Run With Hyundai Tiburon 1.6 Turbo
- N2o Shops I Eu?
- Reinforced Chassis For The Turbo.
- Full Race Manifold On Ebay
- Garrett Gt32 Or Garrett T3/t40e
- Turbo Knock Light By Turboxs
- Need A Tuner In California
- Engine Bay, Airram, Tigerlilly 65mm Tb, Gt28rs Turbo
- Turbo Motor Oil
- Awd Tiburon
- Coustom Intake Manifold
- New Turbo Setup...
- Upgrade Injectors Fuel Leaning At 16psi.
- Holsethy35 Vrs T3/t04e
- Maybe Im Going Turbo?
- Twin Turbo?
- Turbo Piping.
- New Turbo
- Power Readings.
- Upgrades For 97 Tiburon.
- Are 42lb Injectors Controlled Good With My 1.6 Ecu And Safc2?
- Last Minute Questions
- Good, Reliable Source For Turbo Parts?
- Injecter Question?
- Piggyback Ecu From Alpine Develop Turbo Kit
- Looking For Details On Mad_johns Car
- Wanna Save That $1000 Turbo Of Yours?
- Making Charge Pipes
- Weird Problems..
- Crazy Turbo Mount Idea Of Mine
- Big Big Problem When Install Decomp Plate
- Gt28rs Versus Gt3076r
- Should I Get A Smt5?
- Supercharging
- I Need A Clutch For My 1.6 Turbo Engine
- Airram.
- Where Is The 5th Injector?
- Tiburon 2.0 --> 2.0 Turbo
- New Turbo
- Custom Oil Cooler?
- Supercharged With Cai?
- Ecu Swap Kit - Tibminn's Rd2 Is Successfully Swapped!
- Reliability?
- E6k Or Other Standalone Users
- Low Oil Pressure
- Evo 8 Motor -> Tib Swap
- Gas Mileage With Boost
- Prs4 Question
- Max Speed With Boost?
- New Boost Plans, Need Some Opinions
- Wiseco Low Compression Piston Changes In Cc's
- Fpr Adapter
- My Turbo Install..56k No!
- I Have A Problem In My Custom Turbo Installation
- Local Shop Prices.. Pistons And Boring
- Recommended Source For New Intercooler
- Smt Vs Emanage
- Turbo Question
- My Injectors
- Dual Westgates
- Crap Supercharger
- Megasquirt Standalone
- Airram/65mmtb/new Manifold.
- Im = Injector Help
- How High Do You Rev?
- What Electronic I Need For The Turbo?
- Low Compression Gasket
- Fidanza Aluminum Flywheels Hyundai Tiburon 96-7/99 2.0l
- Greddy E01
- Turbo Parts
- Winding Down Boost
- Fmic
- Oil In Compressor Housing
- Octane Booster
- Weird Film In My Oil Catch Can.
- Intercooler Placement
- Questions On Greddy Emanage
- Greddy Emanage Ultimate
- Turbo Kits For 01 Tibs
- How Much Whp Can I Expect?
- Turbo Kit Coming Together
- Turbo Fluttering / Stalling....help
- What Is This?
- Qs For Boosted Guys
- Project Beta2
- Fuel Pump Needed?
- Going Turbo....
- Turbo Manifold
- Compression Ratio Q
- How Bad Is This Manifold?
- Most Efficient Turbo
- External Wastegate/log Manifold
- Some S/c Questions
- What Flange Is This?
- Interesed In Switching To Push Clutch?
- To Recirculate Or Not To Recirculate
- Flow Tested A Stock Head Today
- Emanage Fully Functional :od
- 58mm Performance Throttle Body.
