For Those Of You Who've Made Your Own Aluminum Charge Pipes
Old Mar 31, 2006 | 04:18 PM
supercow's Avatar
where did you find a piece of aluminum for the idle air bypass?
Old Mar 31, 2006 | 04:36 PM
Viper966's Avatar
i am just going to weld in a fitting i think... gonna use a -10an i think... not 100% sure, im doing it right now
Old Mar 31, 2006 | 06:17 PM
Alex01tib's Avatar
if you had a CAI installed before you can use that elbow with the bypass, assuming it was aluminum, otherwise you could just use the stock one.
Old Mar 31, 2006 | 09:47 PM
supercow's Avatar
thats what i thought about doing viper, when i looked on summit thats pretty much all that came up for aluminum pipe.
edit: maybe something like this http://store.summitracing.com/partdetail.a...15&autoview=sku
summit # SUM-220046
double edit: btw, on a quick side note, what the heck does an stand for and how do you measure it??
triple edit!!: air force navy standard
http://www.parker.com/tfd/fittingsol...ANFITTINGS.pdf
and apparently the measurement is in mm??
Old Apr 3, 2006 | 08:28 AM
supercow's Avatar
bump
Old Apr 3, 2006 | 11:21 AM
Viper966's Avatar
i dunno who else's answer your waiting for, im probably the only person who has done this
Old Apr 3, 2006 | 12:23 PM
i would just chop a peice off of a crappy ebay intake. its just a straight ~.5 inch pipe.
Old Apr 3, 2006 | 12:29 PM
supercow's Avatar
QUOTE (Viper966 @ Apr 3 2006, 01:21 PM)
dang, no one has, well I'm planning on going through with the fitting like you. that's all I had come up with as well.
edit: that isn't a half bad idea tibby01, the only reason for not doing that is so i can sell it....
Old Apr 5, 2006 | 04:16 PM
supercow's Avatar
alrighty, I found a better solution yesterday. I went to lowes and found that they do sell aluminum pipe. in 1/2" and 3/4". The 3/4" is a perfect match to the idle air bypass on my cai. plus you get like 3ft. for 5 dollars. cool.gif
Old Apr 5, 2006 | 07:57 PM
good to know man. thanks for updating.
