Wiseco Forged Pistons 97-00 Beta 1 To Beta 2?
Old Mar 14, 2006 | 09:47 AM
dvanderk's Avatar
Does the Wiseco Forged PIstons 97-00 Beta 1 pistons that are stocked by them fit the GK 2003 Beta 2 Tiburon?
Old Mar 14, 2006 | 09:48 AM
Don't see why they wouldn't, the blocks, rods, cranks and pistons are the same I belive.
Old Mar 14, 2006 | 09:51 AM
dvanderk's Avatar
are you sure on this? Whats the difference between these 2 motors then? I have to order new pistons because im burning oil and my cylinder #4 is to blame.
Old Mar 14, 2006 | 09:57 AM
supercow's Avatar
well i believe they changed the head, 2003 is map, and the ecu is alot different.
other than that I'm not sure....jaws??? where are you at?
Old Mar 14, 2006 | 10:01 AM
Pretty sure. Do some searching man, a lot of this is allready answered here, how do you think I know?
LOL
The beta 1 and 2 differences are...
1. Head is a bit different, the 2.5 has the CVVT too.
2. Different sensors, but swappable.
3. Different harness for the engine bay.
4. Different IM, Fuel Rail, Injectors.
5. Different TB.
6. Beta 2 is MAP, Beta 1 is MAF.
That's about it.
Old Mar 14, 2006 | 10:55 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
7. BETA 2 block has more ribs on it
Old Mar 14, 2006 | 11:58 AM
Denisst99's Avatar
pistons will fit,trust me
Old Mar 14, 2006 | 12:08 PM
Jaws021's Avatar
beta II pistons have a slightly higher compression...
I had beta II pistons on a beta I block.. bust fvcken engine EVAH!
Wiseco pistons will fit all 2.0L betas from 97-03.
Keep in mind, wiseco only sells .20 or .40 over.. so your going to have to take the block to a machine shop.
Unless you get a "custom" stock replacement set.
Also to add to redzmans list
* Oil pressure regulator are in different places
* different power steering belts
* different water pumps (old ones are made out of metal)
* Water temp gauge sensor and water temp ECU sensor are combined in the beta II
* Oil pan is very different
* coil packs
* Cams are different..
* alternators are weaker in the beta IIs 85 vs 90
thats all i can think of right now.. do a search and youll find more.
Old Mar 14, 2006 | 09:05 PM
JonGTR's Avatar
The piston design is completely different. I noticed the skirts were designed better in the Beta II's.
