Upgrade Injectors Fuel Leaning At 16psi.
for the guys that have these upgraded parts.
airram, throttle body, turbo.
What size injectors are you guys using?
I thought 510cc fuel injectors was sufficient for my turbo setup.
fuel injectors maxed out at 16psi, so the mechanic detuned the boost to 10psi.
QUOTE (t4turbotiburon @ Jan 23 2006, 09:30 PM)
What about the fuel pump and fuel filter? also did you retune for 16psi? need more info?
fuel pump upgraded to 255LL
fuel filter is the same.
currently on 10psi
sard FPR
can't run 16psi fuel leaning out and fuel injectors on maximum
i'm getting the injectors checked out.
If you bought the injectors new i dont see a problem there it is possible they got mixed up with somone elses but unlikely. I see a more likely problem with your fuel filter if its cloged it will limit the flow of fuel hence limiting hp. Also if you havent had the car retuned for 16psi than that will cause the problem too. Anyway just some thoughts.
