How Can I Put Second Fuel Rail?
Old Feb 17, 2006 | 05:31 AM
fastuning's Avatar
Vehicle: Hyundai tiburon 1.6 TURBO
hi....i have heard many times that the people here put bigger injectors or second fuel rail......but...
how can you put the second fuel rail? what i need? can someone put images of a second fuel rail installed to see how is it? how do you control de injectors in this second rail?
thanks
Old Feb 17, 2006 | 07:48 AM
brian01tib's Avatar
For a dual fuel rail there are alot of things people are still uncertain of. Such as spraying one opp of the other and youll have to drill in the IM and stuff. Just get bigger injectors very easy to do.
Old Feb 26, 2006 | 11:41 PM
renante's Avatar
the mechanics that did the work on my car, never suggested a second fuel rail.
the picture shows it can be done and still look stock and discreet.
mechanic installed a set of 750cc siemens fuel injectors.
this fixed all the fuel problems and vibrating of fuel rails, when boosting and accelerating really hard.
What's the advantage/performance between second fuel rail injectors.
On the picture it looks like you've got 8x fuel injectors.
As against 4x 750cc injectors.
Old Feb 27, 2006 | 12:45 AM
Mad_john's Avatar
save you money homie, go with your 750 or 850cc injectors dont go over a 1000cc you will have a idel problems.. that is the problem that we run in to over here... good ideal but imho its over kill unless you are straight drag racing wink1.gif that cooling fan is a bit small homie get you a 12 flex-a-light
