Found My Turbo :) Finally
Guest
Posts: n/a
here she is.. t3/t40e 50trim
i finally decided on the turbo that i wanted.. i wanted a t3/t40e but i didnt want a higher trim because i wont need it to be maxxing out at 450 hp or so.. my goal is lower than that ~340-360whp and the t3 super 60 trim just wasnt going to cut it..
this turbo comes with a 360deg. thrust bearing instead of the usual 270 deg. thrust bearing.. i will eventually be getting the ball bearing center section for it, but i cannot afford it at this moment.
Compressor Specs:
-50 trim compressor wheel
-0.60AR compressor housing
- Flow Rate 46lb/min
Turbine Specifications:
-Stage 3 turbine wheel
-0.63A/R. turbine housing
-4 bolt standard turbine discharge
CHRA Specifications:
-360 degree thrust bearing standard.
-Oil cooled&lubricated center section
and like i said once i get 500 bucks ill be upgrading to the water and oil cooled ball bearing center smile.gif i think this turbo will be good because a) has a better designed 4 bolt discharge, its pretty much what i need for my power range and will have a fairly good spool up time, specially once i get the ball bearing center section.. just need to get my pistsons all cleaned up now, and get my rods back and ill be all good to go to get my medium monster built up.. nothing like jon, gary, mad-john, viper, can do, but i will do my best for what i have.. cant wait for this baby to get here. smile.gif
Compressor Specs:
Guest
Posts: n/a
Compressor Specs:
Compressor Specs:
Once you get all the "breakable" components of the Tib replaced, you'll want more power. wink1.gif
It's rediculous the amount of power common people are putting down these days. sad.gif
Guest
Posts: n/a
yah my goal was going to be more power, but i am looking into moving into an apartment right now, and i have a baby on the way with my girlfriend, so the tib plans have to be tuned down a bit for a while, and its going to be my daily driver so its only practical to do it this way..
Guest
Posts: n/a
Guest
Posts: n/a
this??
or are you wanting more? i can get the info from tim if you want more.. yeah guys, im buying this stuff from tims new company, lol..
Guest
Posts: n/a
this??
