New Turbo
Well decided to go with a new turbo for next year. I will still keep the holset as i might eventually go back to it or use it for high hp track days or somthing like that. Anyway i picked up a turbonetics T3/t04e Its a .57 trim .50 ar on compressor and a .63 ar stage 3 on the turbine. They say its capable of 40lb a min and 500hp. Dose that sound about right? Like i said im shooting for the 450ish range is this turbo my bowl of soup or do i need to find somthing bigger?
http://www.turbochargers.com/Turbos/TurboU...es/T3-T4-57.htm
Guess my question would be is that whp or crank?
usually you take hte lbs/min rating,multiply it by 10 and it gives you a good "guesstimate" on your max WHP
