Are 42lb Injectors Controlled Good With My 1.6 Ecu And Safc2?
Old Jan 19, 2006 | 04:14 PM
fastuning's Avatar
Vehicle: Hyundai tiburon 1.6 TURBO
hi.....i´m going to buy this injectors from MUSTANG
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...%3AAAQ%3AUS%3A1
only 4 injectors.....
I have a 1.6 Beta engine, Apexi SAFC2 and FPR
can I put this injector and control it for my turbo installation well?
Old Jan 19, 2006 | 04:16 PM
With the SAFC2? No.
Old Jan 19, 2006 | 04:24 PM
fastuning's Avatar
ummm so what is the maX capacity injector can i use with my ECU and SAFC2?
Old Jan 19, 2006 | 04:53 PM
TiburonWao's Avatar
The Stock ones....
Please get rid off that POS SAFC
You car will thank you.....
Old Jan 19, 2006 | 05:06 PM
fastuning's Avatar
i have MAP engine so the SAFC isnt too bad.....
the stock injectors are 184cc/min
so less
Old Jan 19, 2006 | 07:54 PM
Yes, it's very bad, the ECU just learns it's way around the SAFC, every time.
Old Jan 19, 2006 | 08:08 PM
Denisst99's Avatar
you don't want to go over 365cc/min
but like it was told the ECU tries to relearn the fueling and "overcomes" the safc
might be easier with your non obd2 set-up but i haven't played with those
Old Feb 3, 2006 | 02:14 AM
fastuning's Avatar
but what happen if I put 440 cc injectors? i only can control 360cc?
i dont find 36LB injectors of high impedance for my car.
someone can help me?
fastuning's Avatar
Old Feb 3, 2006 | 05:33 AM
JonGTR's Avatar
Look, the SAFC can only turn down injectors at a max of 50%. Since the 42lbs are more than that, then it won't work. So like Denist said, you can't get anything bigger than 365cc.
Now if you got rid of the crappy SAFC, then....................
