Vacuum Lines
Ok guys I just wanted to post up where I think everything needs to go and see if Im even close.
These are all vaccum lines:
From Manifold to manual boost controller
from boost controller to wastegate
turbo gets vacuum from manifold
bov gets vaccum from manifold
from manifold to boost gauge
There are two vacuum ports on my tial 38mm external wastegate. i know one comes from the mbc but what about the other one? Also the BOV (greddy rs) has two ports on it as well. I need help with the extra stuff. thanks
The Top port on the Tial is for a electronic boost controller.
You can use just the top port on the Bov or you can also use the bottom one which should be connected directly to your charge piping. I have ran it from the top for the past couple years with no issues. But you can use both!
