Good, Reliable Source For Turbo Parts?
Old Jan 18, 2006 | 07:36 PM
supercow's Avatar
where do you get your parts at? I'm having a bit of trouble finding these last few things i need.
dp gasket
oil in/out manifold for t3 (the piece you screw the ss hose into and bolt to the turbo)
gasket for ^^ that part
t3 gasket
tib manifold gasket (i know i can get it from the dealer but their prices always suck)
edit: well i found the drain flange (guess thats the name rather than manifold) at road race but not the inlet flange... I bought my pipes off road race, maybe I should to just call them up. their prices don't seem to bad and I bet they could find all this stuff.
Old Jan 18, 2006 | 07:51 PM
summit racing should have all of that.
tib manifold gasket...
http://store.summitracing.com/partdetail.a...15&autoview=sku
dp gasket is a 2 bolt one right? what size tubing?
http://store.summitracing.com/egnsearch.as...1566+4294920576
t3 turbine gasket...
cant help you on the oil block peice thingy though.
Old Jan 18, 2006 | 07:54 PM
supercow's Avatar
oh when i said dp gasket i mean the end attached to the turbo 3 -bolt, not the 2 bolt on the flex pipe. and it's 2.5"
thanks for those links!
edit: the gaskets on that link are 3 bolt!
http://store.summitracing.com/default.asp?...1566+4294920576
that one will take care of it i think.
so that means just those inlet/outlet flanges.... I'll give road race a call tomorrow to see if they have the inlet as well.
Old Jan 18, 2006 | 08:02 PM
are you talking about that funky looking gasket?
http://www.eiptuning.com/eip/flanges.html
i think your oil return peice is down there too.
edit- another place that has the gasket with the oil flange thing. in europe though...
http://www.dp-engineering.nl/oillinekits.html
more...
http://www.prostreetonline.com/store...turbo_gaskets/
Old Jan 18, 2006 | 08:04 PM
supercow's Avatar
well I could just screw the ss line right into the turbo but I thought i'd get the flange and do it the right way. but you can't screw the drain in. it's not made that way.
I don't see the inlet flange on that page though. that drain looks nice though, guess I'd have to make a gasket. I'll have to check my ss dump hose though, I think it's bigger than 1/2". rr's it's 5/8.
edit: have you purchased from any of these places besides summit though?
Old Jan 19, 2006 | 03:47 PM
only summit acutally, but ive heard good things from prostreet.
Old Jan 19, 2006 | 07:41 PM
Alex01tib's Avatar
thanks for the link to summits exhaust manifold, i was just wondering where to get them without getting a$$ raped.
On a side note, not to hijack, but if you used two gaskets on the exhaust manifold would it still seal good? because i had a relatively new gasket and it still leaked, a friend told me to use two gaskets, i didnt know whether that was a good idea or not.
Old Jan 19, 2006 | 07:56 PM
if it leaked, chances are your manifold was warped, or you didnt torque the nuts down to proper specs. its supposed to be crushed a wee bit when the manifold is smashed down over it, and that crushing is supposed to eliminate any leaks due to the gasket.
i guess its possible you just got a crap gasket if you made sure it wasnt because of the first two things though.
Old Jan 19, 2006 | 08:06 PM
Denisst99's Avatar
for the exhaust manifold gasket i prefer the OEM one...
fel pro wil lbe made of composite and the stock one is 3 layers of SS much better ;-)
for it to seal well your manifold need to be straight
Old Jan 19, 2006 | 08:10 PM
is it really ss? cause that thing was pretty chewed up when i took mine off.
