Turbo Knock Light By Turboxs
Old Jan 26, 2006 | 08:47 PM
Saw one on ebay and was wondering if anyone was using somehting like this with a turbo application. Heres a link:
eBay Link
Input Please!
Old Jan 26, 2006 | 08:53 PM
instead of gettin some cheezy knock light invest in a wideband o2
you shouldnt knock when your stoich so....
Old Jan 27, 2006 | 12:58 AM
Jaws021's Avatar
actually it is safe to have BOTH.
A knock light would be VERY useful. It could have saved me an engine sad.gif
The only problem i see with that auction is that your paying 120 for the LIGHT only. It does not include a knock sensor.
If you are using the stock ECU, then you can just reuse the stock one. I would research this further, you might be able to rig up your own Knock light or find one cheaper.
You could have a nicely tuned car,.. but that one stop you from pinging on a hot day or on a day that you fill up with "bad" gas...
Old Jan 27, 2006 | 02:07 AM
Mad_john's Avatar
use hi grade gas, keep your shit in check, make sure its tunned right. that way you save your money homie
wink1.gif wink1.gif .. i am not sure but buy the time that thing blinks to tell you, that the engine is knocking, it is to late??
better to run a "little" bit rich, then to go "BOOM"
Old Jan 27, 2006 | 06:46 AM
JonGTR's Avatar
A motor is going to knock all the time. The ECU just reads it and retards the timing enough to keep the knocking low. If it's low enough, then the ECU will add timing. It's constantly adjusting.
Stoich (14.7:1) is never good on a FI car. They usually like around 12:1
