High Hp = ?# Injectors
I'm having a hard time finding high impedance injectors over 48lbs. So I'm thinking I'm gonna have to install a resistor box with the standalone to run the bigger low impedance injectors. What are you guys using right now? Have you found some big high imp. injectors?
You don't need a resistor box with it? Is there setting in the program I'm missing?
Vehicle: Had 96 Elantra Wagon
Let me get the page for you and I will post it up.
Ok I can't find the page now,but for the low impedance injectors you have to run 2 injectors per output, and it will be running in batch.
If you need more help let me know and I will send you my wiring on mine, but I took the stock harness and modded it so there is only 12 wires running to the bay.
I already have 42lb green tops, but they're not gonna support over 280whp. I want something like 83lbs.
So running batch with only 2 outputs will allow you to run the lower or high impedance naturally? But running 1 output to 1 inj. will only allow high imp.?
QUOTE (Tim @ Mar 8 2006, 03:53 PM)
msd peak/hold 750.to 850 anything bigger will give you issuse at idel.. summitracing has them for i think its 98 or 95 a pop.
Vehicle: 01 Tibster
How much power are you planning on running? No need to overkill.
I've got the same 42lb green top injectors and I'm a little over 300whp. I could probably push them to 350whp if I wanted to.
It's all about engine management.
